08-30-2019, 01:13 PM | #1 |
Secondary air injection "EGR" plug
So I removed the air injection on the side of the engine head, because it was causing back firing with my new "catless" exhaust.
Instead of making a block-off plate, I took the risky move and tapped a thread for a M12 x 1.5 bolt. There a lot of metal shavings making the thread, I used a shopvac about every turn of the thread. The aluminum head is very soft expect shavings even when tightening a bolt. I got several bolts to try. If the anodized red is too much I can always spray some high temp black primer on it. Let me know what you guys think!
BaShan BSR 250 DB-41H 2018 Red BS250GY-18D JFG Racing Exhaust . Adjustable Shock 320mm . Brozz Digital Gauge . Renthal Fat Bar . 428 17x46 Sprocket . Fender Eliminator . Wheel Truing . Fuel Tank Repair . Keihin PZ30 Main-115 Pilot-38 Needle-1Washer Fuel Mixture-1/2 BSR Chronicles - "Project leads to more projects!" Yamaha WR250R Suzuki GSX-R 600 |
08-30-2019, 05:10 PM | #2 |
A stainless pipe plug just came in, this might be the winner here. Can't wait to try it.
08-30-2019, 08:29 PM | #3 |
I have flat steel plates for this task.
Or you can cut the pipe n weld the hole or make a plate |
09-02-2019, 12:41 PM | #4 |
Interesting solution! I never thought of tapping the hole.
09-03-2019, 12:02 AM | #5 |
Here are some new pics. I put on anti-seize and a coat of high temp black.
09-03-2019, 12:05 AM | #6 |
I would have gone for high temp red loctite and called it a day
09-03-2019, 03:28 AM | #7 |
Again there is a plate and gasket available - just blanks it off directly
09-03-2019, 04:57 AM | #8 |
Be careful. I have heard of people shredding the rear tire from all the added power. With all the weight reduction and power, the front wheel becomes useless.
2020 Kawasaki KLX300R, 2018 Yamaha TW200 If you want more of something, tax it less. If you want less of something, tax it more. |
09-04-2019, 12:46 AM | #9 |
I made a blockoff plate from the iron crate the Hawk came in for my TT250 head, and put 3/8 rubber plug from the HW Store. Cost was probably 12 cents. Cheap bike gets cheap solutions LOL
1983 Honda Xl600R 2016 Ducati Multistrada 1200S DVT |
