04-30-2023, 09:15 PM | #1 |
Square drive screw - valve adjustment tool
Using square drive screws as valve adjusters
05-01-2023, 12:06 AM | #2 |
I've heard of people doing that. I can see where it might be very useful especially if there are clearance issues. I just use my long needle-nose pliers to hold the square tip while tightening the nut. Then recheck the clearance of course, as we all should do.
2021 Lifan Xpect--sold 2022 Lifan KPX 1972 Honda CT90--The Carrot 1969 Honda CT90--The Tomahto Cheesy is the WDK (workplace drama king). Now retired. Nope, back in the saddle. Nope, finally retired. Climate: The Movie https://www.youtube.com/watch?v=A24fWmNA6lM How our government really works https://www.youtube.com/watch?v=QjadCd0VRBw Question all authority.....think for yourself |
05-01-2023, 07:40 AM | #3 |
Yeap, much thanks to @JerryHawk for pointing me in that direction in the past, it works great to hold that vanve stem while you work on tightening the nut
2024 Templar 250 2021 Beta 500 RRS 2018 VStrom 1000 XT Former China Bikes: Tao DBX1, Brozz 250, CSC RX4, Titan DLX, Templar X, Storm DLX 150 |
05-01-2023, 07:40 AM | #4 |
I made that kind of tool when I got my CX500 back in 2010. I have an open end wrench that fits the adjusters but twirling the dowel stock with the screw in it is a heck of a lot quicker.
05-01-2023, 07:45 AM | #5 |
The only difference is mine was more high tech. I used a wire nut on the end of the screw.
05-01-2023, 08:39 AM | #6 |
I have seen a Suzuki owner with impossible clearance make one with a reduced length square drive screw screwed and glued into a square wooden dowel numbered on each side so it's blatantly obvious when you reach a perfect 1/4 turn and also by centering the edges 1/8 turn. Also affixed was a long length of string to allow any dropped tool being easily retrieved out of the engine. He made two, an ultra short and a long for both front and rear cylinders on the V-twin he had.
