07-02-2018, 07:47 PM | #1 |
Bull 150-D still no spark...
Gentlemen,
I am known to be a patient man, but I am beginning to lose my patience with this ATV. I have replaced the ignition coil, put in a new CDI, and a new spark plug and I still have no spark. I even took the coil off and turned the ignition over several times to check to make sure I was getting current at the end of the coil cap where it plugs into the top of the spark plug, and I am getting voltage. What am I missing here? Thanks for any help you can offer. |
07-03-2018, 04:43 PM | #2 |
Did you check the foot brake safety switch? Pull on the switch plunger and give it a try. (make sure it isn't in gear) If its really bad you can just jump the connectors on the plug.
Would check the kill switch too... the internals could be jacked up. |
