HELP * Intake Manifold Cracked *
so after almost 2 years.
all the rubber on my bike has pretty much dried and cracked. So where can I find a replacement for the Intake manifold? |
Cracked Manifold Tip 'o' the Week
Remove the manifold, any o-rings, and apply masking tape to each end as they mate to the carb and cylinder. Block the monting holes from the "nut" end as well. Go to your hardware store and get a container of Plasti-Dip, hopefully they will have black in stock. This product is used to repair and insulate tool handles and such. Clean the manifold of any grease or contaminants. Apply a coat to the outside, wait until it dries completely, then apply some more. make sure to work the Plasti-dip into the cracks. Be neat about it, and dont try to apply too much at one time. Stop when you feel you have applied enough to make a healthy coat. Let it dry completely and reinstall. Unmask the manifold |
That's a great idea there Ob1! Ought to stick this little morsel in the Tech section there Frostbite!
2009 XR650L Big Red Pig Tusk bar risers 2007 X-Moto(Jetmoto) GY250 --mods--- 15/40 sprockets UNI Pod Filter 2007 Shineray TMS 200XYi--Betsy ![]() Betsy Mods:______________________ Acerbis DHH headlight FMF Powercore pipe Uni Pod Filter |
