Old 04-23-2016, 06:41 PM   #1
pete   pete is offline
pete's Avatar
ABS units...
do those ABS units that fit between the caliper & master cyclinder
work??.... thinking puting one on the side car wheel..
These
http://www.aliexpress.com/wholesale?...Id=32227483937
09 XT660R ...
06 TTR250 ...
80 Montesa H6 125 Enduro...
Current resto projects..
81 Honda CT110...
80 Kawasaki KL250A1...
http://www.remotemoto.com/
E-mail... xtpete1@gmail.com
Old 04-23-2016, 07:57 PM   #2
humanbeing's Avatar
https://translate.google.com/transla...082&edit-text=
Old 04-23-2016, 09:34 PM   #3
pete's Avatar
Thanks....
Now I see whats in them.... it can NOT work..
there is no way that can rejuce pressure
it can & dose slow the time the pressure takes
to build up... thats the time zone the anti lock works in
but pressure WILL build up to full brake pressure in
the end... no anti lock when that happens...
I thought they may have had a stack of belvue cup washers
in them to rejuce the pressure.... but no...
It would stop wheel lock up on those quick stabbs
on the brake... may be all thats needed..
Think I will just put a brake bias valve in the line to the side car wheel...
09 XT660R ...
06 TTR250 ...
81 Honda CT110...
