03-27-2008, 10:53 PM | #1 |
carb screw settings
can you see the threads on your screw? I am just wondering how far they stick out normally. I just took mine apart to clean it so I am not sure
03-28-2008, 10:19 AM | #2 |
I wouldn't go by threads, but number of turns out. Probably want to start at about 2 turns out.
Turn the screw all the way in until is stops, but don't turn it really tight. Then back it out two complete turns. That should get you a base setting where the bike will start and run. You adjust form there. Allen
03-28-2008, 11:12 AM | #3 | |
03-28-2008, 11:22 AM | #4 |
Just to clarify that we are talking about the fuel mixture screw and not the idle screw. The idle screw you will see threads.
Allen
04-01-2008, 11:14 AM | #5 |
I would also strongly advise unscrewing the threads and applying locktite and then set them correctly so they do not move from vibration. I would use blue or red.
04-01-2008, 04:19 PM | #6 |
use blue loc-tite* cause red will be very diffucult getting it off.....the screw is onlt brass right?
04-01-2008, 08:43 PM | #7 |
I wouldnt use locktite. Brass and aluminum with locktite means new parts next time you need to adjust.
