08-12-2018, 09:40 AM | #1 |
Coolster 125 bogging out when hitting throttle
I have a couple of Coolster 125 with the same problem...
They start fine and idle fine. If I bring the throttle up at a moderate speed they have plenty of power and speed. But if I hit the throttle fast, they die out. Is this normal? I've tried adjusting the idle and a/f using these instructions https://atvconnection.com/forums/1-e...-sunl-etc.html without success. The only way I can get it not to do it, is if I put the idle up a little high, which of course then it's idling too fast and causing clutch engagement. Is this behavior typical? |
08-12-2018, 11:28 AM | #2 |
I have a 2017 Coolster, and it had the same problem. I purchased the new lever choke style carb, and moved needle clip down to the number 4 or 5 position. It solved the bog problem, but I ended up with some surging when cruising.
I ended up changing to a different style Carb. I can't remember the settngs, but I was able to get the ATV to run pretty good with it. This is the one that I purchased, but if you buy this unit it will most likely ship from China, and take about two weeks to receive. It will also require a new air filter. The opening is much larger, and the stock air filter will not fit. Here is the one that I purchased. https://www.ebay.com/itm/EPA-Approve...item25ff57b6a5 https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 This one looks to be the same, and ships from California. https://www.ebay.com/itm/PZ22-Carbur....H0.Xpz22.TRS0 |
08-12-2018, 04:54 PM | #3 |
You might just want to try lifting the needle all the way to the top ,not sure if you have any more slots or if a few washers are needed .
