09-12-2022, 08:29 PM | #1 |
Fueling Problem
My 2019 CSC TT250 begins to hesitate and then cuts out at high RPM in 5th. It will stall but then restart after I pull over. Otherwise it starts and runs perfectly.
I’ve cleaned the carb and jets, set the needle to the next richest setting and replaced the main jet with a bigger one but the problem remains. Any ideas would be most appreciated! |
09-12-2022, 08:41 PM | #2 |
Adjust the valves.
09-12-2022, 08:46 PM | #3 |
09-12-2022, 09:18 PM | #4 |
Can you give an exact rpm or is it a bit random.
09-13-2022, 12:20 PM | #5 |
is your fuel filler cap vent hole plugged?
09-13-2022, 12:34 PM | #6 |
Thanks for the question: Above 6000
09-13-2022, 12:36 PM | #7 |
I tried riding with it cracked but there was no difference.
09-13-2022, 12:37 PM | #8 |
I adjusted them recently and they’re quiet but I’ll try it again.
09-13-2022, 02:02 PM | #9 |
It's not about them being quiet, it's about them being not too tight. Especially the exhaust valve. At minimum you want .06 mm intake and exhaust. Personally I would set exhaust at more like .10 mm.
09-14-2022, 07:01 PM | #10 |
Csc states the lash spec as .07mm with a check interval of 2500 miles.
09-15-2022, 11:58 AM | #11 |
I set mine to .06mm and the ticking is very audible only going away at certain RPMs, so quiet on these engines is a bad sign from what I've gathered. Though I've always been paranoid that I did some type of internal damage when I first adjusted on the exhaust stroke, and had to replace a brand new spark plug that somehow grew a much larger gap than it started with. In that case even after proper valve adjustment I had missing at high RPMs until putting yet another NGK in there.
Tags |
carburetion, cutting out, rough running |
