11-01-2020, 06:12 PM | #1 |
Took the bike for its second ride, first "real" ride.
Not being registered, I loaded it on the back of my truck and hauled it to my buddy's house, unloaded and what do ya know... it started pouring. I didnt load it for nothing so I ended up going for a ride anyways. One things for sure, I need to get hand guards asap. But being almost winter, maybe I'll build it up for spring throughout the winter. Put almost 40 miles on today so not horrible. Runs as well as the stock carb let's it run. No issues to speak of yet...
11-02-2020, 04:25 PM | #2 |
So I ordered a digital cluster and wheel speed sensor that goes to it but the wheel speed sensor looks a little different than the oem hawk sensor. As in this one is like a female setup and the oem hawk is make. So the hawk has the part sticking out that goes to the wheel, the one I received has one that goes inside from the wheel hub... I will try to send pictures later. Any ideas??
11-02-2020, 04:45 PM | #3 |
FYI. When you go to post the picture you must reduce the file size to 97kb or smaller in order to post. This is a walk around until we can correct the issue of automatic file reduction.
11-02-2020, 08:02 PM | #4 |
Sorry I'm on here from my phone. I will try it from my computer
