04-06-2021, 05:33 PM | #1 |
Trying to lower my Hawk
Hello, I have a new 2020 Hawk 250 and I would like to lower it around 2 inches. I would like to do so by replacing the shock. I am 5'8" and about 220llbs.
I was wondering if anyone can suggest a proper shock for me. Everything is stock on the Hawk currently. This is my Hawk posted in this thread Thank you in advance! ~Steve |
04-06-2021, 06:43 PM | #2 | |
The original unit is 320mm center to center, and roughly every 10mm difference in length lowers the bike 1 inch
04-06-2021, 07:23 PM | #3 |
You could pay $250 and buy a seat concepts seat which lowers your butt about 2.5" and takes about 15 minutes to swap out.
04-07-2021, 12:09 PM | #4 |
I am your size and ride with a passenger often too on my TBR7 with this shock. I think the bikes are similar enough this should work. It is slightly shorter and I did not have to mess with adjusting it. Originally lowered the adjustments on the factory shock and it was awful.
ZXTDR 290mm 11.42" Rear Shock Absorber Suspension Sensa-Trac Load Adjusting for Dirt Pit Bike Motorcycle 1200LBS https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 Buy a bunch of 10mm washers to make up for the width different at the mount points. It is a better quality shock and lower. I also lowered the front forks down about an inch where the handle bars mount sticking up about an inch further. |
04-07-2021, 01:36 PM | #5 |
The stock shock on my tbr7 was 300 or 305mm in case you find someone that wants to donate you a shock.
04-07-2021, 03:16 PM | #6 | |
