04-05-2021, 04:24 PM | #1 |
Erratic Speed Odometer ?
I was out to the farm on my bike today (Brozz250) , and on the way back I noticed that when I would open my bike up on the straight stretches, like fully accelerating from around 40mph to about 55mph, that my speedO would randomly flash high numbers , like 75, and 82 , while accelerating, and then once my speed became steady it would display as normal. I have never messed with the front wheel since I assembled it. I used red wheel bearing grease that I have on hand when I did assemble it. Could it be working it's way onto the pick up for the speed O ? I didn't notice it doing it anymore after I ran it at a more consistent speed . Is this normal, and something that I may have just missed? My bike has a little under 400 miles on it now.
04-05-2021, 09:39 PM | #2 |
My Brozz 250 did the same thing when new. Speedometer was fine until I hit about 5000 rpm and the Speedo went nuts. Dropped below 5000 rpm and all was good. I contacted Jeff at Peace Sports. He had me try a few things that didn't help (Check wiring connections on cluster). He contacted Bashan and they said to replace the instrument cluster. He sent a new one out under warranty and I installed it. Presto! Problem solved. I have put over 3000 miles on the bike with no further issues.
04-05-2021, 10:47 PM | #3 | |
04-06-2021, 04:02 AM | #4 |
I had to live with an erratic speedometer/odometer ever since I got my Zong second (or third...) hand. When I got it, the odometer was reasonably accurate but the speedometer was waaaay too optimistic, showing e.g. 110 km/h when cruising with 80-90 km/h.
Things got weirder since: I replaced the tires it came with new ones, and the front one was not exactly the same size as stock: 3.00-18 (new) vs 100/90 (stock) was about 7-8% smaller in diameter. That alone resulted in a 7-8% bump in odometer and speedo readings. The speedo was now WAAAAAY optmistic, easily pegging at 140+ km/h if I tried a top speed attempt, and showing 120 km/h during cruising (which, I think, might have had a part in ultimately breaking it). At some point however something must have broken inside, and after a removal to service the speedo cable and investigate a squeaking noise, it lost a lot of oomph. The speedo needle now has a bit of a bounce but on the upside it's now actually pretty accurate (90 km/h is 90 km/h, 100 km/h is 100 km/h), but the odometer has shifted closer to a 20:23 ratio aka 20 indicated km are 23 real km. For quick mental calculations, 7:8 works as well Of course that increases the risk of running out of gas if you don't "recalibrate" your interpretation of the odometer from time to time...ask me how I know And who knows where it will go next... |
04-06-2021, 09:09 AM | #5 |
The speedo on my 2020 Brozz 250 was consistently off since new. Optimistic is a good word. It would show 60 when a GPS would show 52 - 53. I purchased a compensating device called a Speedodrd, (Honda H1). It was $70, but I thought worth it because it being off so much was driving me nuts. I had to change pins on the connections to get it wired correctly. It has been working fine. I set it to report 12% lower which puts it close to the GPS reading.
It has on occasion at start up, randomly start displaying numbers, racing up to 6 digits, and adding miles. It will stop if I shake the bars, and lock up the front brake or shut it off of course. Nothing seems loose, and the sensor doesn't have a bunch of grease loaded in it. I talked to the company and they said Chinese bikes are notorious for "dirty" electronics. He suggested I add a .01uf capacitor. I'm not sure exactly how to do that so it's still just a suggestion at this point. I have noticed it is not happening with the same frequency as before. So less of an issue. I do really like having a speedo that is close to accurate. Kind of a pet peeve I guess. My truck is off too. When it shows 45, it's really doing 42 - 43. My wife's Camry is dead on. And my 74 MGB is dead on also through a completely mechanical system. Interesting to hear of other problems with the speedo. John |
