Old 03-06-2015, 09:54 PM   #1
phillieswon   phillieswon is offline
Gy200 engine parts- Valves
I have a green redcat gy200 and in need of valves. My intake is bent with only 60 miles. I can't seem to find any. Does anyone know where I can source them?
Thanks in advance for any suggestions
Old 03-06-2015, 11:27 PM   #2
Thanks for starting the new thread. I'm sorry I missed your PMs, my mailbox was full. I needed to delete a few old messages.
If you post photographs of both sides of your engine, we can verify the model. Then I'm sure someone will offer a good suggestion to help you find a new valve.
Old 03-07-2015, 02:16 AM   #3
Welcome!
As Spud says, pictures will help.
Old 03-07-2015, 08:44 AM   #4
humanbeing's Avatar
Measure it 1st, some brand can't use the mainstream CG200 parts...
"Individual" chinese bike mechanic likes these quality brand : 正洲 (VTC) -Taiwanese brand that made locally / 大东 (DDQM) -Based in Chongqing , many bike's stock valves are supplied by them...
Parts supplier in Guangzhou
DDQM : http://item.taobao.com/item.htm?id=38679462803
Generic: http://item.taobao.com/item.htm?id=38516771834
Old 03-07-2015, 11:01 AM   #5
I didn't know that! Thanks for your terrific info as always, HB!
Old 03-07-2015, 01:15 PM   #6
X2; thank you, Humanbeing.
Old 03-08-2015, 07:54 AM   #7
humanbeing's Avatar
Mainstream CG200 are like this http://item.taobao.com/item.htm?id=14516420402
Old 03-08-2015, 09:30 AM   #8
I didn't realize that CB valves were that much larger than CG valves.
Old 03-10-2015, 07:56 PM   #9
Gy200 redcat
Here it is, anyone know what replacement valves I need?
Thanks
Old 03-10-2015, 11:06 PM   #10
That's definitely a CG. Can you measure the valves?
Old 06-23-2015, 10:02 PM   #11
It runs!
I was able to find a valve that fit but had to take it to a machinist to move the keeper groove further down the shaft. Is there anything I should do as it still isn't broken in yet? My mech set the timing, so should that prevent another bent valve? he said that the valve could have been stuck open from sitting too long.
