Old 11-13-2015, 04:20 PM   #1
RX3James   RX3James is offline
RX3James's Avatar
Real fuel economy??
Ok everyone what are you really getting on your RX3? I typically fill my tank as full as I possibly can. After a 68 mile group ride last Friday morning and riding back and forth to work all week I traveled a total of 101.8 miles. I put in 2.955 gallons of premium today topping it off.. so after some quick math I'm averaging 24.23 miles per gallon.. how is that even possible? I ride very conservatively and I don't hot rod around town.. I've done one oil change and the valve adjustment. I've always used premium fuel and there's only 940.9 total miles on the bike. So what's up? Did I just get the one and only gas hog RX3? I'm kind of upset that I'm getting less than half of the advertised MPGs.. any suggestions to improve my fuel economy?
Old 11-13-2015, 04:24 PM   #2
Danimal   Danimal is offline
Banned
101.8/2.955=34.55 mpg
still low.
I seem to be averaging around 58mpg or so on mine.
Old 11-13-2015, 04:32 PM   #3
RX3James's Avatar
You're correct it should read 34.55 MPGs.. Still less than half of the advertised 70 MPGs. I cant for the life of me figure out why im getting such poor fuel economy. I take really good care of the bike and like I said before I ride very conservatively. So who knows...
Old 11-13-2015, 04:51 PM   #4
NoVa Rider   NoVa Rider is offline
Obviously something's not right. How does it start and run? Is oil level holding steady? Any signs of black smoke from the exhaust?
First thing I would check is the air filter. Any sign of blockage? Maybe too much oil on the filter? If that looked OK I'd take out spark plug and check for rich running. And at that point I would give CSC a call.
Old 11-13-2015, 07:45 PM   #5
I average about 68 mpg, which is about twice the gas mileage you are getting. I think NoVa offered good advice; I would do as he suggested.
Old 11-13-2015, 08:49 PM   #6
Lee R   Lee R is offline
Lee R's Avatar
55 average for me. Best I've seen is 58.
Old 11-13-2015, 11:04 PM   #7
58 mpg is the worst gas mileage I've recorded. However, I ride conservatively.
Old 11-14-2015, 05:38 PM   #8
X2.
Just spit ballin' here; perhaps an O2 sensor that is on the way out might not yet have triggered a code, but it could be causing the PCM to dump too much fuel in.
Also, does the bike require premium? I'd challenge the notion that premium would result in higher economy, if the bike only requires 89.
Old 11-14-2015, 06:27 PM   #9
Lee R's Avatar
It doesn't require premium and you won't see any benefits.
We do have non-ethanol at all the Stewarts shops around here which is what goes in both my bikes. You do get better mpg with non-ethanol.
Old 11-14-2015, 08:00 PM   #10
That's what I figured. What does the manual recommend for octane? Does it specify R+M/2?
Old 11-14-2015, 08:32 PM   #11
Page 6 of the Owner's Manual specifies the following.
Fuel: Minimum 87 Octane
However, the white sticker, placed on the left side of the frame next to the triple tree, specifies the following.
Fuel: Unleaded Gasoline - 91 (R+M)/2
Old 11-14-2015, 08:38 PM   #12
I was burning regular fuel, which is 85 (R+M)/2 at Great Basin elevations. However, Gerry recommended a higher octane, so I switched to 87 (R+M)/2, which is the fuel I burn in my Honda CRF250X.
https://en.wikipedia.org/wiki/Octane_rating
Old 11-15-2015, 01:21 PM   #13
RX3James's Avatar
The bike starts and runs with no issues. The only thing that I've noticed is that at times it runs pretty hot. 4 bars is fairly standard for a normal day of riding around SoCal. I'm going to take a look at the air filter and the spark plug today and see what they look like.
Old 11-15-2015, 01:26 PM   #14
RX3James's Avatar
Forgot to mention the oil level is holding fine and there are no signs of black smoke or anything like that. I haven't seen anything on the instrument cluster indicating any fault codes. As far as running premium.. it's just something I've always done with my motorcycles. Just force of habit I guess..
Old 11-15-2015, 01:55 PM   #15
When the engine is cold, make sure to check the coolant level. Also, keep the overflow bottle full, until the coolant level stabilizes. Most of the RX3 bikes are low on coolant when shipped from the factory. The routing of the radiator hoses tends to leave an air bubble in the left radiator.
