06-08-2023, 09:16 PM | #1 |
Need help in identifying main jet type
Some time ago i bought chinese knock-off of Mikuni VM24 carb, and today i tried to disassemble and check it out. Well, i'm kinda puzzled. Pilot jet is not marked at all, and what is supposed to be Main Jet is of a very strange design, and i can't find any relevant information on the internet. I suspect that it's not even a mikuni type of jet. Anyone have ideas about what it is? Compatible carb models? It has 97.5 marking on it.
Would be really glad for any help.
"My life is falling apart like a chinese motorcycle" 2020 Viper TXM200R - A clone of 1982 Honda CM125C, powered by 200cc CG thumper. Mods: Windshield, leather panniers, kickstand, LED Headlight & Fog lights. |
06-09-2023, 09:07 AM | #2 |
What Jeffrey said.
06-09-2023, 10:51 AM | #4 | |
Guys, i'm not sure if i should create a new thread for that, and i understand that this is more of a trial-and-error thing, but what would be your recommendations on correct jet sizes for stock 164fml - 200cc CG engine (no head decking or porting), with a twin exhaust manifold.
06-11-2023, 08:50 PM | #6 |
Hey, dirtbkr188, huge thanks for providing the reference. That 97.5 main jet corresponds to mikuni measurements on the pic you've attached. The mystery of the default jet is solved ) However, i'm still a bit puzzled - i have a set of main jets that i ordered from Aliexpress, that are supposed to be Mikuni-type. They are of the same 9mm length and compatible threading, but have larger head of 8mm... If i understand correctly, that's another Mikuni standard. Do they have the same sizing numbering system as those with smaller heads?
