11-14-2022, 09:20 PM | #1 |
aftermarket exhaust for ZS172FMM
I have been looking for an aftermarket exhaust system with straight through piping to complement the 249cc ZS172 engines.
I see lots of pipes out there, including many SS headpipe/midpipe systems. But I don't know if the eaxhaust port geometry and diameter will work. I keep seeing Honda CRF150F CRF230F CRF250R 2003-2016 Is this for the ZS167 head? Installing one of these would be much easier, and frankly, cheaper in terms of hours into fab work (!) than modifying the stock system. And the diameter of some of these is wider than OEM. Any advice would be greatly appreciated. |
11-15-2022, 07:32 AM | #2 |
I'd be interested in this as well for the Temp X.. otherwise its on my list for a friend to weld it back together after i cut and tear out the cat
2024 Templar 250 2021 Beta 500 RRS 2018 VStrom 1000 XT Former China Bikes: Tao DBX1, Brozz 250, CSC RX4, Titan DLX, Templar X, Storm DLX 150 |
11-15-2022, 07:39 AM | #3 |
This is the header pipe you would need. https://www.orionpowersports.com/sta...-249cc-engine/
