04-10-2019, 09:24 AM | #1 |
Clutch not fully engaging?
My bike doesn't roll easy in gear with the clutch in like it does in N. What to adjust?
Thanks |
04-10-2019, 01:13 PM | #2 |
Theres an adjustment at the switch housing under the rubber cover on the clutch lever , you can run that in or out to adjust it.Also make sure the oil you are running is rated for use with wet clutches . All that said , it's pretty common for these clutches on the Grom clones to be a little "grabby" up until about 300 to 500 miles when they get worn in , so if you have really low miles it's likely that more than anything.
04-10-2019, 05:01 PM | #3 |
I am using this stuff
Rotella T5 Synthetic Blend Diesel Engine Oil 15W-40 |
