#1351 |
I use high octane fuel in my Honda CRF250X. This is 89 octane in most places, but is only 87 octane at Idaho elevations. Therefore, I am inclined to follow the Zongshen Owner's Manual, and use high octane fuel in my Zongshen RX3. If high octane fuel is not available, I'm confident one can use regular octane fuel when necessary.
#1352 |
After some research I have found that the parts used in the carbureted and fuel injection engine are different. So be careful determining parts by the available lists that are linked here.
#1353 |
I am happy that the tolerance is smaller with this engine. The newer engines with higher quality parts are going to smaller and smaller valve clearances. This is a great thing to know the overall quality of the materials used in the valves and the seats.
#1354 |
I can't wait to get my hands on an engine along with the bike. I will be developing parts for more HP ASAP. Short list would be valves, springs, cams, pistons, rods, and cranks for internal engine parts.
#1355 | |
#1356 |
Once a person becomes accustomed to the process, I'll bet that it can be accomplished while the oil is draining.
#1357 | |
I'm grateful that all of my bikes and atv's have threaded adjusters.
#1358 | |
Thanks for the very interesting video, Spud. I was surprised to see how messy the process is, and I'm looking forward to seeing the ChinaRider solutions that are developed over time. It appears to have a brass drain plug with a magnet epoxied in it. I recommend that each RX-3 rider buy a spare drain plug, in case it should become cross-threaded. It would be wise to use a little anti-seize on the threads. I'm glad to see a sight glass. My Bro-in-law's XT350 has neither a dipstick nor a sight glass. Most annoying. Did anybody spot the snow track gear at 13:25? I wonder if they've adapted it for use with the bike in the video.
#1359 | |
#1360 | |
![]() I always drain my oil with the bike on the kick stand. I will also be expecting a lot of oil to issue from that coarse oil filter. ![]()
#1361 |
Weld,
I had not noticed the snow track gear. You are a keen observer. ![]() ![]()
#1362 |
Wonder how many people have actually compared the lash measurement on a hot engine vs. cold? Back in the 80s I had a bet going with the mechanics at the motorcycle shop I worked at. We checked several bike engines cold and hot, push rod and OHC. All were looser when hot though the OHC engines showed less difference than the push rod engines.
#1363 |
Banned
Lash adjustment & specs.
I hope that someone at CSC can double check the exhaust valve specs for us at least. That MAY be why the intervals are as short as they are because thats not a lot of leeway for being out of tolerance, and a burnt exhaust valve would be a real possibility with no lash gap when it got hot and expanded.
I'll be a bit "nervous" when I first am riding the bike, especially on the initial ride back home that 2300 miles +...I will probably try to check them (and adjust if necessary) at CSC before leaving. Its not what I want to do enroute from Cali to Bama, for sure! Love the threaded adjusters though, and the reusable oil filters. They absolutely WILL NOT collapse in very cold weather with thick oil either! So safer there as well... This will prove to be a REAL time saver when servicing the bikes, IMHO. They will not need any more adjustment than any other motorcycles, IMHO, as they should all wear a similar amount of time/miles after initial break in and settling. Does anyone know the suggested oil viscosity or does it have a differing cold and hot recomendation? Oil change suggested intervals (after break in?) I holp I can avoid that as well on the way back.... Also is the chain o ring, or do I need to pack a can of spray chain lube? If not o ring, thats going to be the first upgrade ![]() |
#1364 | |
#1365 | |
![]() ![]() http://www.chinariders.net/files/Zon...ers_manual.pdf If you check recent posts, you will also find links for the Gas Gas and AJP bikes which employ the Zongshen NC250 engine. ![]() The RX3 specifications state the bike comes with an O-ring drive chain.
