Old 08-02-2022, 01:38 PM   #121
Teklock   Teklock is offline
Originally Posted by JimS View Post
Yes that is the manual that I have. It does show the 165ML-P engine and our newer engine is 165ML-E and it would be nice to know for sure the correct lash. I may leave what I have for now as that same manual shows that the 165ML-P is an air cooled engine in the introduction (section 1.1) and on the next page (1.2), it states it is water "colled"....
I sent an email to American Lifan to see if they can confirm the correct measurements and possibly send a manual for the 165ML-E.
Since MY2020 they moved over to the 165ML-E so I would follow the specs for that engine which are .08 and .12. It's the same engine in the KPM and that manual also states .08 and .12. Let us know what Lifan tells you though! It would be super cool if someone could get a new service manual for this engine!
Old 08-02-2022, 01:44 PM   #122
JimS   JimS is offline
Lifan responded with .08 intake and .12 exhaust so I'll leave mine as is.
They didn't mention the availability of a service manual and I did ask.
Thanks
Old 08-02-2022, 04:09 PM   #123
Falkon45   Falkon45 is offline
Falkon45's Avatar
You guys have the NBF2 engine, like the KPM and KP, from what it looks like. That's the spec you'll be needing.
Old 08-02-2022, 05:19 PM   #124
Do you know if "NBF2" is only referred to the 165ML-E engine? I'm asking because it appears that is a marketing term and may include other engine models.
Old 08-02-2022, 05:26 PM   #125
Falkon45's Avatar
From my research, Yes. I've not seen the NBF2 name and any other engine model or size show up in reference to each other.
Actually, I'm wrong. Well damn. That code shows up in an article for the KPR150 also. Guess I should have double checked first.
https://www.motorcyclevalley.com/rev...-mahmud-razon/
Old 08-02-2022, 06:36 PM   #126
herbie   herbie is offline
Dang guys I'm extremely sorry about the wrong information on valve clearance specs! I originally posted a video with the owner's manuals specs and after seeing teklocks post on page 3 I thought that was for our newer model KPR, I guess I was wrong. I had taken my original video down and reposted this one with what I thought was new correct information. Anyway I will remove this new video and either post the old one or remake it. Geez
2022 Venom KPR 200 Red- the fastest color
16t and 46t sprockets, NGK Iridium CPR8EAIX-9, aftermarket full exhaust system. Top speed 81GPS
2023 Venom SS3 KP mini 150– Nibbi carb, Nibbi air filter, aftermarket muffler, decat
2022 Venom Ghost chopper 250
1997 Honda GL1500 Goldwing
1978 Kawasaki KL250
https://youtube.com/@herbiesgarage681
Old 08-02-2022, 06:44 PM   #127
No worries herbie! Your video helped me do the adjustment in about an hour and is greatly appreciated.
Old 08-02-2022, 07:01 PM   #128
Thanks for understanding Jim, I feel awful about that. I know there is some useful things in the video, oh well back to square one.
1978 Kawasaki KL250
Old 08-02-2022, 09:07 PM   #129
I received a reply from American Lifan stating that the service manual is not available to the general public.
Old 08-02-2022, 09:32 PM   #130
I haven't had the chance to do my valves yet so hopefully you'll post another video herbie! Maybe just edit the video where you had the specs and just print the other specs on the screen?? Either way, Thank you for all your videos!
Old 08-03-2022, 06:54 PM   #131
I plan on making another video maybe on Saturday morning with the owners manual specs if I get the time to. Setbacks just make you stronger
1978 Kawasaki KL250
Old 08-03-2022, 07:21 PM   #132
Thumbs Up
I like the quote!
Old 08-04-2022, 07:05 PM   #133
Coming up on 700 miles and thinking about replacing the chain. The bike has always been a bit noisy from 4500 to 6000rpm and I "think" it's chain noise.
Any recommendations for a replacement? Should I put an O- ring or X-ring chain on or stick with the standard roller chain?
Do you guys notice noises in the rpm range mentioned above? It's been a bit noisy from day 1 and runs great so I assume it's normal.
I did my 1st top speed run today and hit 74 on the speedo. Not sure how you guys are hitting 80+ . I'm 185 pounds and was tucked behind the windscreen.
Old 08-05-2022, 08:02 AM   #134
For street riding on concrete or asphalt a standard chain is good but if you ride on dirt or gravel roads an O-ring or X ring chain would be better.
2004 Honda ST 1300
Old 08-05-2022, 09:18 AM   #135
Like Jerry said a standard chain is fine and is what I run as long as it’s good quality but you need to clean and oil it more often. If you don’t like doing the maintenance then o or x ring chain would be better. As far as top speed several factors go into that on a small displacement/hp motorcycle. Has the chain been lubed, axles greased, bike roll easily, tires properly inflated. But the biggest thing in this bike is obstructed exhaust flow. I opened mine up so it’s less restrictive, at the upper range with stock exhaust the power falls off. If you uncork the exhaust the engine will rev better especially in the upper range
1978 Kawasaki KL250
