04-25-2020, 11:22 AM | #121 |
Seem crazy that a full size X22R is so light at only 254 Lbs. Thanks for paving the way with all these mods Jerry. If Venom ever gets them Street legal in Canada I might get myself one.
Electrician & Electronics Tech 2014 Honda CB500XA 2016 CSC TT250 1976 Honda CJ360T 2022 Honda Navi |
04-25-2020, 11:58 AM | #122 |
They really are good bikes. I’m absolutely loving mine. I pretty much follow Jerry’s mods as he makes good choices and has good taste! lol
2019 Venom X22R K&N pod air filter, removed cat, 105 main jet, 36 tooth rear sprocket, RK racing 428 chain, oil cooler, NGK plug, bar risers, aftermarket mirrors, Grab On grip covers, phone mount/charger, Pro Grip tank protector, Chase Harper tank, tail, and saddle bags. |
04-25-2020, 12:30 PM | #123 |
You sure they are not street legal I Canada?. These bikes are shipped out of the Canada warehouse.
04-25-2020, 12:31 PM | #124 |
that's what my wife said.
04-26-2020, 09:02 AM | #125 |
Well I got the Wiseco 11:1 piston and Hot Cam ordered. Not the wait. Hopefully it all will be here Friday. I'll have a weekend project with the porting and install.
04-26-2020, 04:48 PM | #126 |
Gonna do the single layer gasket with the piston for the extra bump?
04-26-2020, 05:06 PM | #127 |
11:1 on an air cooled engine is already pushing it. It needs to be reliable as I use it for a daily drive.
04-26-2020, 08:17 PM | #128 |
If anything I would spring for a thicker gasket. This is basically what I wanted to do with an re250.
04-26-2020, 08:28 PM | #129 |
Yes I have the stock crf230f gasket ordered. Once I pull the head I can calculate the CR.
04-26-2020, 09:19 PM | #130 |
It's a lot of red tape to get a bike legal in Canada, to my knowledge CSC and CCW are the only road legal Chinese bikes. Venom talked getting a few legal years ago but nothing came of it. They only have ebikes that are street legal here.
04-27-2020, 04:12 PM | #131 |
Canada must have the same EPA regulations as California.
04-27-2020, 07:58 PM | #132 |
I emailed Venom. They are still waiting on approval from the government.
2024 Linhai 300 ATV 4x4 2023 Lifan Lycan 250 Chopper 2023 Venom Evader 2022 Lifan KPX250 2020 Kawasaki Vulcan S (Sold) 2004 Honda ST 1300 2016 Black Hawk 250 (sold) Keihin PE30 carb,125 main,38 slow.Pod filter,ported & decked head 10:1 CR,Direct Ignition Coil,15/40Sprockets,NGK DPR8EIX-9,De-Cat,Dual Oil Cooler,Digital Cluster 2016 Cazador180 XL 2014 Coolster150 JerryHawk250.com My YouTube Channel Last edited by JerryHawk250; 04-28-2020 at 02:43 PM. |
04-27-2020, 09:23 PM | #133 |
In Canada, it's federal only, not provincial. You have to give a bike to them to destroy and you can't make any changes once it's accepted. If you do make production changes, you start over. As a result, few China brands have ever hit the road in Canada.
05-01-2020, 02:57 PM | #134 |
Well i got the piston in today. Cam will be here on Monday.
2024 Linhai 300 ATV 4x4 2023 Lifan Lycan 250 Chopper 2023 Venom Evader 2022 Lifan KPX250 2020 Kawasaki Vulcan S (Sold) 2004 Honda ST 1300 2016 Black Hawk 250 (sold) Keihin PE30 carb,125 main,38 slow.Pod filter,ported & decked head 10:1 CR,Direct Ignition Coil,15/40Sprockets,NGK DPR8EIX-9,De-Cat,Dual Oil Cooler,Digital Cluster 2016 Cazador180 XL 2014 Coolster150 JerryHawk250.com My YouTube Channel Last edited by JerryHawk250; 05-01-2020 at 03:46 PM. |
05-01-2020, 04:39 PM | #135 |
Just curious. Would the hot cam work well without the higher compression piston? I guess the higher compression helps low end power that can be compromised with a long duration cam.
"Its not WHAT you ride; its THAT you ride" |
