03-31-2021, 09:22 AM | #121 |
The TC125 is on hold as I wait for a base gasket... should be here this week. Evidently only England makes them... lol.
Honda Z50a is together but waiting for tank liner as there was a pinhole leak in the tank when I filled it up.
1988 Kawasaki KLR250 1969 Honda Z50 silver tag 2002 Ford F-350 7.3 diesel 1975 Corvette 2017 Chevy Bolt “Throttle twisting geek” -LFN |
04-13-2021, 11:27 PM | #122 |
04-13-2021, 11:30 PM | #123 |
Lots of eBay parts, but trying to get it right. I think the reason this bike was turned into a parts bike was, left crank seal had fallen out... wasn’t any good either. So, it quit running, no one could get it running and it slowly lost parts as people tried and failed. I got the flywheel and the stator plate off and sure enough, seal was hanging out...
04-19-2021, 12:23 AM | #124 |
Runs! Many weirder small issues including a very large mouse nest in the expansion pipe that then plugged the exhaust. Took about 1/2 an hour after removing baffles to get it all out. Points were garbage. Got them filed tho and great spark now. Gas on/off valve leaked. Fixed that too.
1988 Kawasaki KLR250 1969 Honda Z50 silver tag 2002 Ford F-350 7.3 diesel 1975 Corvette 2017 Chevy Bolt “Throttle twisting geek” -LFN Last edited by Landsvw; 04-19-2021 at 05:25 AM. |
05-02-2021, 12:13 AM | #125 |
Getting closer
Getting there. Got my seat recovered today. The 30$ seat cover arrived.
06-03-2021, 08:47 AM | #128 |
Not much to report.
But, found a little treasure trove of motorcycle junk. Bought some of it. A Kawasaki 125 and an XR80 engine. Trying to sell the 1971 F6 Kawasaki 125, And my kayak. So far, no takers. A few interested. Organized and piled a few extra parts to go with it, including an upper end of a 1980-90 water cooled CR125 I also had laying around… spring cleaning. Heheh. Want to ride the Suzuki but it’s been 100 degrees here after work this week. Ugh! Put together the XR80 engine and seems like almost all the parts are there. Looking for a rolling frame to put the engine in. That’s it! Happy Thursday!
06-03-2021, 08:51 AM | #129 |
Just run it WOT to make the AC work better. lol
06-04-2021, 07:34 AM | #131 |
What no ride report?? lol She looks nice.
06-04-2021, 09:08 AM | #132 |
Runs great! Took a 10 mile ride on her. Has power, shifts well, and runs like it’s supposed to. Had been working out the bugs until last weekend. Found the carb had a bad o-ring in it and was running rich. This bike has a carb with a removable from the outside main jet, which is in horizontally. So, where the main jet passage in the bowl hooks to the upright continuation of the passage there is an o ring. Had gone bad…
06-18-2021, 08:49 AM | #133 |
Got enough parts for 1 and 3/4 of an XL75! Working on it now
06-18-2021, 09:33 AM | #134 |
Cool project, I always liked those little bikes. I was at walmart yesterday and they have something new, it's a 3" thick by 2'x3' sheet of high density foam. If they had that when I recovered my seat I would have used it, may be good for your project. Best of all it was less than $8.
2022 Venom KPR 200 Red- the fastest color 16t and 46t sprockets, NGK Iridium CPR8EAIX-9, aftermarket full exhaust system. Top speed 81GPS 2023 Venom SS3 KP mini 150– Nibbi carb, Nibbi air filter, aftermarket muffler, decat 2022 Venom Ghost chopper 250 1997 Honda GL1500 Goldwing 1978 Kawasaki KL250 https://youtube.com/@herbiesgarage681 Last edited by herbie; 06-19-2021 at 08:59 AM. |
06-20-2021, 10:22 PM | #135 |
I did the electrolysis rust removal treatment on the XL75 tank and seems to have worked! Calcium carbonate, and a battery charger for like 12 hours. Negative on the tank and positive on the suspended anode in the solution. Bubbled away, creates hydrogen i think, and then rinsed with water and solvent at the end. Didn’t start leaking either which was my greatest concern…
Edit: it started leaking. Dang it!
1988 Kawasaki KLR250 1969 Honda Z50 silver tag 2002 Ford F-350 7.3 diesel 1975 Corvette 2017 Chevy Bolt “Throttle twisting geek” -LFN Last edited by Landsvw; 06-22-2021 at 10:53 AM. |
