Old 01-27-2011, 10:47 PM   #121
midlifekrisiz   midlifekrisiz is offline
If that means the operator, you might be right.
BINGO you win a xtra large double double .....we'll buy
Old 02-21-2011, 06:11 AM   #122
I worked on the exhaust a bit more sunday mainly making a clamp and sizing the pipe for a tighter fit, no picture sorry. (no big deal)
I did take a picture of the hideous wiring mounts I made,....I dont know why I took the picture but here it is.
I like the nuts welded where things get mounted it just makes it easier to work on later.
(I try to limit the amount of loose nuts I have to deal with )
I still have to make a mount for the ignition switch and wire in the headlight, taillight, nuetral indicator light and high beam indicator light as well as the clutch switch.
Old 02-21-2011, 02:28 PM   #123
Jim   Jim is offline
Sounds like it's coming a long
"Be excellent to each other"
Old 02-21-2011, 11:11 PM   #124
I say abandon this project now. That engine belongs in your new mini bike.
Old 02-22-2011, 05:54 AM   #125
That engine is bigger than that minibike besides I have a 250cc polaris with CVT that I want to stuff in the minibike.
Old 04-13-2011, 08:37 PM   #126
Ok some fresh pictures.
Old 04-13-2011, 08:39 PM   #127
Hers a vid of me getting a little crazy in the yard.
Its running pretty good but I did have to put a 107.5 main jet in it and I may still have to fine tune some more.
Old 04-13-2011, 08:41 PM   #128
Hey that looks great! Congratulations on your project!
Old 04-13-2011, 09:12 PM   #129
mizke   mizke is offline
looks very good awesome job..
i wonder what the blaster frame weighed compared to the china frame.. it seems it might be a good bit lighter cuz my 200cc quad with mods and a rejet cant ride a first gear wheelie that good with out some serious yanking up and mashing the throttle at the right time..
200cc beast replica,carsoli cdi,performance coil,fmf powercore 2,uni air filter,hour/tach meter,jetted mikuni carb,msr bars,moose racing grips,yz250f clutch perch,D.I.D chain
Old 04-13-2011, 09:41 PM   #130
Thanks for the kind words guys I am very happy with it so far.
So far it seems to be working well but I wont call it done until I get several trouble free hours on it.
It does have a lot of nit picky things that I have to do to it and I plan to paint the frame red this fall if its still running and in one piece.
It will pull the front end somewhat easily but I think the weight bias has a lot more to do with it than people think.
My wifes raptor 350 is almost impossible to get the front end up on which is what I wanted for her.
My 300ex is a wheelie machine and will pull the front end up with ease which is what I like when having to climb over a fallen tree.
The blastard is in the middle of those two.
Old 04-13-2011, 09:47 PM   #131
oh believe me buddy i more then understand just how much the power to weight ratio means.. thats how a turbo'd 4banger honda can run with a cobra. the honda only needs about 350-375whp or a little less to run with a 500hp cobra due to the cobra being some where in the 4000-4500pd range and the honda 2000-2500pds..
if you remove 4lbs off the rotational mass of a cars flywheel, it has the same effect as removing 100pds off the body of the car in terms of acceleration..
Old 04-13-2011, 10:52 PM   #132
That looks store bought! I'd be worried about busting spindles on my China quad riding on both right wheels like that.
There's horsepower hiding in that muffler.
Old 04-14-2011, 06:02 AM   #133
I wasnt talking about the power to weight ratio's I was talking about the weight bias/weight distribution having an effect on on how easy or hard it is to pull a wheelie.
At some point when you have gobbs of horse power it will just easily overcome the weight but on a little 200cc atv with modest HP its more of a matter of where the weight is on the ATV overall.If I had put that engine farther forward it would take a lot more to pull the front end up.
I jammed the engine as far back as it could go for chain reasons more than weight distribution.
Weldandgrind It does have a bent left spindle already (I have another) but I have no worries with that frame although they will break.
There is all the work I did to it to worry about but overall I can beat it hard and it will come back for more.
That exhaust is more open than I thought and I will most likely have to rejet it again.
I'm sure your ATV would hold up just fine.
7" of suspension travel is nice and I hope I can use it all soon, I cant hardly wait to get it up to the trails..
Riding it on two side wheels like that is easy and fun I love how easy the blasters are to ride.
I have to do some serious work on the rear brakes because they are almost unnoticable.
Old 08-13-2011, 07:47 PM   #134
OMG
I just came in from checking the intake manifold I made for leaks and............its a leaker.....well was a leaker, I got a lot of them welded up but I still have to clean/grind on it and recheck.
I took it off the quad because I ran it and noticed a backfire and seen a small jet of fuel shooting out of the manifold side when it backfired. :roll:
I removed it and made a couple of block off plates for the ends and one has a air hose fitting that I was putting about 15-20psi into then checking with some leak detection solution you can buy most anywhere.
It still has a few very very small leaks that I'll take care of sunday.
Old 08-13-2011, 10:12 PM   #135
Maybe you could tap the intake tube for pipe thread, which would allow you to install a small barb. The benefit is that you could connect a vacuum gauge to confirm that there are no leaks, and you could use it for tuning. As I understand it, the air / fuel screw will be at the correct point (at idle) when the vacuum signal is the highest.
BTW, if there is a vacuum leak, the gauge will bounce.
