06-22-2018, 10:05 AM | #121 |
They are both. 1 1/8 in the center with 7/8 ends at the controls/grips.
https://www.aliexpress.com/item/Blac...3da24c4d3Xj8Sm
06-23-2018, 12:21 AM | #122 |
I will say this, recording stuff and assembling adds about double the time to the job. Waiting on my video to export and then I can upload it to youtube.
06-23-2018, 02:57 AM | #123 |
Cylinder Head Intall!s
I decided to take my mind off of wiring for a little bit and tackled installing my ported head.
After I got it all back together and spun it over slowly to make sure nothing bad was going to happen I installed my new spark plug and decided to give it a good kick or two. She definitely is a lot harder to kick over than my last one! Still not super hard, but it is definitely a noticeable increase in pressure. I did a leakdown test to make sure all was good and sealed as well and she is good to go! I can't wait to start her up now. Just the motivation I needed to finish up. I also added this post to my resource guide under DIY/How-To so hopefully other people will find it helpful.
06-23-2018, 06:38 AM | #124 | |
2016 Brozz |
06-23-2018, 06:43 AM | #125 | |
I have two different types on hand. The current ones were a pair I bought but never installed on my Hawk, so I decided to try them this time around. This is the style I am currently using. https://www.aliexpress.com/item/1-Pa...ceBeautifyAB=0 The other style I have are the ones previously installed on my stolen bike. These replace the top caps. https://www.aliexpress.com/item/Pro-...52884c4d8kixGS
06-23-2018, 07:11 AM | #126 | |
Another question what would you think about running both types of oil coolers at the same time? ie the head cover type and the other bottom filter adapter type.
2016 Brozz |
06-23-2018, 07:38 AM | #127 |
Great videos Dan! Maybe in time a rear wheel / Front wheel / Grease sealed bearings video would be helpful to some new Hawk owners on here.
I just did mine along with swing arm after 1700 hard miles of mud water & sand also highway & lucky I checked because grease in bearings was very bad & swing arm had no grease at all. Also replaced rear brake cylinder & pads which were toast. |
06-23-2018, 08:01 AM | #128 |
Nice video thanks. I see that piston in the hole about .030 or so im have to address that issue when i assemble my extra parts im ordering. Lol
06-23-2018, 11:08 AM | #129 | |
increase in pressure, only from head inlet and exhaust porting? or something else? Thanks! |
06-23-2018, 11:17 AM | #130 | ||
The piston deck height is far more than .030" I didn't have my verniers on hand to measure the depth though.
06-23-2018, 11:48 AM | #131 |
well done job on the video....
06-23-2018, 12:02 PM | #132 |
Nice video Dan! it will have a little more thump to it at idle too. Well while you're putting you bike together I'm heading out for the day and put some miles on mine. I had to stop in and check on the progress. Lol
06-23-2018, 12:12 PM | #133 |
From decking the head I installed 1mm, which also had a shallower quench band milled into it than the stock head. If my measures and math are remotely accurate, I am sitting around 10.3:1 compression.
06-23-2018, 09:30 PM | #135 |
try shorting the header pipe...
on the TTR 5" /125mm shorter gives 1.5hp with the standard muffer & 2.5 with the GYTR pipe.. lose a bit of bottom end but gain in mid to top... being a everybodys trail bike they are tuned for a good bottom to mid range power... pipe and air box opened up and the TTR really takes off... the Hawk could be simluar.. being a 250 you tend to spend most of the time in mid range revs and up... 3000 plus... Dyno figgers... http://ttr250.activeboard.com/t64301...ore-and-after/ ..
