Old 09-20-2018, 09:04 PM   #121
Lucastheking   Lucastheking is offline
Originally Posted by Chinabike View Post
Its the hose that comes out of the top of the engine. Its connected to the emissions/air box.
If you remove air box then you put the uni filter on the end of the hose that was connected to the air box.
Would take a pic for you but i'm not around my bike.
OOOHH its when it remove the airbox? thanks man i havent done that yet cause i still have the stock carb on ill do it when i change the carb then, thanks man
Old 09-21-2018, 06:56 PM   #122
yes only when you remove the air box, then you will have the filter on the the crank case hose.
Old 09-30-2018, 06:47 PM   #123
Help!
I can't get me rpms higher then 6-7k topping out speed 50mph wot.
After moving from a 105 main jet to a 95 main jet. Needle clip middle.
vm22 carb
when i had a 110 main jet in it would get 58mph but would bog at 3/4 throttle
Whats should i try, think i'll try back up main jet
Old 10-02-2018, 01:41 PM   #124
wlfpck   wlfpck is offline
Where are you located? I'm running a 110 or 115 main.
Have you done a plug chop to see if you're lean or rich? That's probably where I'd start.
2020 Honda Grom
2017 Icebear Fuerza (Daix PMZ125-1) - Sold
Old 10-05-2018, 07:11 PM   #125
cali, yeah i was running rich at #115 #110. #105 was still a little on the rich side.
I'm running good now at #100 still need to run it some more. I think changing my pod filter mess up my tuning.
Old 10-15-2018, 03:33 PM   #126
Gman828   Gman828 is offline
Guys, had my TaoTao on the road for about 2 weeks and it has started no idling. Any idea what may be going on? Made a video to show what it was doing but can’t figure out how to upload it.
Old 10-15-2018, 06:43 PM   #127
Whisky   Whisky is offline
Whisky's Avatar
I found out that fine tuning the idle is best where the throttle is mounted on the handle bars. After u get it smooth there then set it on the carb. I fought a high/low/no idle for days.
2018 BD125-8-x21rs
ZS190/Genuine PE28
Kepspeed GP1 Exhaust
Protaper se x110 bars/grips
1/4 MotionPro throttle
Kepspeed Braced swingarm
Chimera rear hub assy
Grom Intergrated tail light
Superlite Sprockets 17/32
custom made from Japan
Chimera Swing Arm Bolt
RK MXZ Chain #420
All Balls wheel bearings
Motodynamic fender eliminator
Coremoto ss brake lines
Composimo 2.5 lower link
Grom Calipers-w/ebc pads/rotors
Michelin tire 140&120
13x4/13x7 fatties
Grom forks
Old 10-16-2018, 06:28 PM   #128
No idle? You check the plug? rich/lean.
Upload the video to youtube and post the link.
Old 10-29-2018, 12:04 PM   #129
Open the carb up and check the pilot jet. If it's clogged, could be an issue.
Throw the video on youtube and post the link.
2020 Honda Grom
