03-17-2017, 10:54 AM | #121 |
This has been an ongoing mega-hassle for me! I cannot, for the life of me, find any 1.25" regular (read cheap) exhaust tubing around Sac anywhere..... Even the internet is elusive.
03-17-2017, 10:59 AM | #122 | |
03-17-2017, 11:01 AM | #123 | |
i have used this before with good results... not the lightest but hey... half my go cart frame is that stuff too... and most of the exhaust... and the exhaust on my 1964 Magna garden tractor... pipe is pipe |
03-17-2017, 11:13 AM | #124 |
I think they had used some kind of glue to hold it in place. with 10k on it the glue was more than likely burnt off. Maybe heating it up with a torch might loosen up the glue.
03-17-2017, 12:28 PM | #125 | |
03-17-2017, 10:23 PM | #126 |
Storing that Jack space wise is the issue with everything , right? It will be the best 70 spent. Will use it constantly
03-18-2017, 07:35 AM | #127 |
Another option is the $29 jack Item#66552,it's a space saver.
03-18-2017, 08:08 AM | #128 | |
i bought this jack last year, it works great, i got it on sale for around $70 but they wouldnt let me use the 20% coupon, if you look in the "fine print" on the bottom you will see its not valid for "floor jacks" i guess they consider a motorcycle jack as a floor jack but its still worth a try. still worth it though even if they dont let you use the coupon, i have 3 bikes and soon to be 4 and i use it quite often. |
03-18-2017, 09:31 AM | #129 |
A Rose by any other name.
I gave my bike its first real ride at around 150 miles distance. It worked great. I was able to cruise at 65 no problem and it would do 70. Iam now able to red line the engine in 5th gear when needed. Started out with around 450 miles on the speedo ended up with over 600 on it. That is about 1/3 the total ridding its had in one day. Also installed a new tachometer, volt meter and 12 volt / dual usb charging station. The bike is faster now then it was when I started out on this trip. Seems like my pile o s**it has grown a Rose! So I rename her from pile to Rose. This counterbalanced engine was smooth as silk even at 8000 RPM. I could ride this thing all day with no problem.
03-19-2017, 10:24 AM | #130 | |
A locking ring pin like this. I can't remember the size. |
03-19-2017, 11:16 AM | #131 | |
03-19-2017, 10:24 PM | #132 | |
03-20-2017, 07:58 AM | #133 |
I added tie-down strap rings for when I put her on the trailer when we go on our next camping trip. I also went from a 115 main jet to a 120. I took her out Saturday and was running a little lean. I put just over 225 miles over the weekend.
2023 Lifan Lycan 250 Chopper 2023 Venom Evader 2022 Lifan KPX250 2020 Kawasaki Vulcan S 2004 Honda ST 1300 2016 Black Hawk 250 (sold) Keihin PE30 carb,125 main,38 slow.Pod filter,ported & decked head 10:1 CR,Direct Ignition Coil,15/40Sprockets,NGK DPR8EIX-9,De-Cat,Dual Oil Cooler,Digital Cluster 2016 Cazador180 XL 2014 Coolster150 JerryHawk250.com My YouTube Channel Last edited by JerryHawk250; 03-20-2017 at 10:27 AM. Reason: fixed link |
03-20-2017, 10:17 AM | #134 |
Pics are not showing up.
03-20-2017, 10:28 AM | #135 |
Thanks, fixed it. Not sure what happened but shows up on my end.
