#121 | ||
Happy to serve. |
#122 | |
http://www.securitycamerasdirect.com...or-lcd-monitor The CX has a manual adjuster whereas the GL has and automatic adjuster. Both models have an inspection plug above the flywheel to align timing makes for valve adjusting. The hole is large enough to get a dental mirror in there to get a gander at the tensioner. There you can see how stretched the spring is and how much adjustment is left. From the look of mine, this little bit of maintenance was never performed. Here is where I learned to do it. http://cxgl.wikispaces.com/Cam+chain+inspection
#123 |
I'm glad I asked both questions.
![]() ![]() Spud ![]()
#124 |
Wow, that chain carved up a lot of aluminum. I bet the oil looked like Never-seize when it was drained out.
#125 | |
![]() I think I've caught mine in time. My oil is still looking pretty clean.
#126 |
Camera got here today but too busy to play with it. Got lots o' time tomorrow, will post up some pics then.
#127 |
Here is the camera. Here is more info from the manufacturers website. http://www.whistlergroup.com/inspect...ct.aspx?id=285
![]() Actually a bore scope because it doesn't save images. Still, way cool. Didn't play much but I did use it to confirm what I already knew about my cam chain. The inspection hole on the CX with the plug removed. ![]() Tensioner with no adjustment left. ![]() I still needed to use the dental mirror but I think I got a better image using the scope. Cam chain ![]() For giggles and grins, I pushed on the cam chain with the handle of the dental mirror. Yeah, my season is done. :( I'm surprised that the chain hasn't been thrown. Also think I may have broken a chain guide on Wednesday and may have just started sawing into the aluminum.
#128 |
Sounds like you caught it just in time. I'm very interested to follow the process, as I might like to add a CX to the stable someday.
#129 | |
Every o-ring in the cooling system is being replaced as is the mechanical seal and water pump seals. Rear brake shoes will also be replaced and the forks rebuilt. Headset freshened or replaced, depending on condition, same with the wheel bearings. This is all stuff that should have been done last season, but Mrs. Cheesy was on such a rampage about the me bringing it home that I decided to let sleeping bit.....er...dogs lie. Now, she wants to know how long it's going to take to get it back up and running. :?
#130 |
Glad the Mrs. is on board. 8)
As far as the headset bearings go, if I go through the effort to repair them I just swap them out with tapered rollers. They ride better and will never wear out. Not expensive, maybe $50 or less. I use All Balls but I think any brand will work.
Happy to serve. |
#131 |
That must be a common thing on the CX's... Mine piled up the chain and broke a guide shortly after I bought it. Kinda soured me on the bike after that, Lol, I had spent all my savings to get it!
#132 | |
#133 | ||
#134 |
Two spare motors for $60?
May be worth the shipping... http://spokane.craigslist.org/mcy/3329180961.html
Happy to serve. |
#135 |
Nice find, Doc!
![]() Spud ![]()
