#121 |
Buy the tie downs. :wink:
Easier and safer and less messy and faster and less risk of a complication than removing the caps. ![]() Also gives a real world in situ diagnosis. You won't be riding the bike with the caps off so results may not be applicable.
Happy to serve. |
#122 |
X2. Besides, a pair of decent ratchet tie downs are usually less than $10.00. They're very handy to have.
#123 |
I don't think I would have enough leverage to ratchet the tie downs to achieve maximum fork compression. :?
I am starting to become convinced I will never hit this oil cooler with the front wheel. Here is a photograph of a rider who bottomed out the suspension of his XR650L after a jump. 8O ![]() However, please note, he replaced the stock forks with USD forks. ![]() Here are two doctored photographs showing how far I would need to compress the forks to get the wheel to hit my oil cooler. ![]() ![]() I think I am going to trim the rear of my front fender a bit more, so the wheel would contact the oil cooler before it caught the fender. I don't want to catch the wheel on the fender, and go flying over the handlebars. 8O If the fender is trimmed short enough, do you guys think I will ever impact this oil cooler with my front wheel? :?: In my retouched photographs I'm almost as close to hitting the exhaust header as I am to hitting the oil cooler. :roll: Spud ![]()
#124 |
its an XR lowrider.
#125 |
Spud, I wouldn't worry about it, unless you catch major air when riding. I don't; I'm too old for that nonsense.
You can certainly get enough leverage with ratchet tie-downs to fully compress the forks. Like Doc says, load it in your trailer and crank the tie-downs. If you have a helper, you can even do it with cam buckle tie downs.
#126 |
https://fbcdn-sphotos-a.akamaihd.net...58829241_n.jpg
Wow! That is major bottoming! It almost looks like a Z50 now! ![]() |
#127 |
I think that's cool that he fit USD forks on that XR. I wonder if it will be a major challenge to fit USD forks on the KLR250. Hmmm...
/hijack
#128 |
Yesterday I decided to figure out how much the forks could compress before the front wheel impacted my oil cooler. I removed the front fender, placed my XR650L on a stand, and measured the free sag at 1-1/8 inches. Taking the bike off the stand, I measured the travel from the wheel to the bottom of the oil cooler at 9-1/2 inches.
![]() Adding the free sag to the last measurement, I got a total wheel travel of 10-5/8 inches. The front forks of my XR650L have a total travel of 11-5/8 inches. Therefore, the wheel will impact my oil cooler in the last inch of travel. ![]() Since the weather was nice, I rode my XR650L for 56 miles on the freeway, without the fender, to discover the highest level of cooling I could expect. ![]() I maintained 75-80 mph the entire time, and passed a lot of automobiles along the way. :P My oil temperature did not exceed 255 degrees; I am pleased with this result. ![]() ![]() I am going to trim my front fender a bit more, to ensure the wheel will not impact the fender well before it would impact the oil cooler. ![]() ![]() ![]() Spud ![]()
#129 |
I'm still shocked at that baseline number. 8O Most cars would be in trouble at that level. What is the psi rating on the cap?
#130 |
This is where the advantage of L/C comes into play. The downside is complexity, the payoff is performance. It's all a balance...
Spud, I'm curious if it handled better on the freeway without the fender. I've therorized and read that D/S bikes with large floppy high front fenders suffer from the wind affecting the steering at highway speeds and I bet it's true to some degree.
Happy to serve. |
#131 | |
![]() The oil system is very low pressure in these bikes; there is no psi rating on the oil dipstick. ![]() ![]() Spud ![]()
#132 |
I don't recall Spud, do you run synthetic in the BRP? I think I would. :wink:
Happy to serve. |
#133 |
No, I am currently using Mobil Delvac, 15W/40 diesel oil.
#134 |
The temp sensor on the lifan motor from my vapor was in the 230+ range.
(this is from the spark plug area. the sensor replaces the washer for the plug.) this was in cool weather, |
#135 | ||
