Old 10-27-2024, 05:07 PM   #121
mtgldr   mtgldr is offline
Originally Posted by TominMO View Post
JT Sprockets. JTF1264.14, currently sold out on Amazon. They do have other sizes though.
See this pic. Shows the inner hole measurements.
https://www.jtsprockets.com/catalogue/part/JTF1264/
After my third sprocket coming back for more advice... I the interior dimensions of the sprocket are 17mm x 20mm. Problem is the teeth on the factory sprocket are significantly narrower than the teeth on the sprockets I have purchased. The JFT Sprocket Drawing reflects the teeth larger than the gaps between the teeth. My sprocket is the opposite, the teeth are smaller and the gaps are bigger. When I line up the factory and replacement sprockets, it's as if the teeth and gaps are the exact opposite of each other.
Any idea's?
EDIT: I found a JT 1264.14 Sprocket on a West Coast website - Sprocket Center. They have several options for size. Hopefully it's in stock. Will report back after installation.
