12-17-2016, 02:47 PM | #121 |
There she be! Fits pretty well. I'd like the bottom to be a little tighter but the wrinkles should leave as the leather ages.
1988 Kawasaki KLR250 1969 Honda Z50 silver tag 2002 Ford F-350 7.3 diesel 1975 Corvette 2017 Chevy Bolt “Throttle twisting geek” -LFN |
12-17-2016, 02:50 PM | #122 |
sweet
12-17-2016, 02:58 PM | #123 |
How would I rate the quality? Good. Definitely leather at all body contact points. Back fit very snugly. Bottom maybe a little loose. But, all in all, good. It actually matches the plastic trim pieces better than the old one, which I assume was somewhat faded and obviously dirty too. Lariat script is sewn in, whereas the old one was pressed in I think. No one will ever know the difference tho I bet. Next upgrade my Euro headlights and the door and finally the carpet.
12-18-2016, 11:01 AM | #124 |
Now the rest of my seat looks shabby. I'm going to try some leather cleaner, dye, and conditioner later on and see if I can make it look better. No rips or tears, so don't want to change it out.
12-18-2016, 12:49 PM | #125 |
Nice job!
Do you have heated seats? Any complications about that? Maybe careful use of a heat gun will remove the wrinkles; it works on vinyl.
12-18-2016, 03:52 PM | #126 |
No to the heated. I'll just let nature take its course. I'm sure the leather will relax as time goes on...
12-23-2016, 11:16 AM | #127 |
Thursday I installed emergency brake shoes, as I had noticed one had come loose when I did the original brake job. 13$ for the set.
Yesterday I spent changing the rear end and transfercase oil/fluid. I pulled the cover off the back and inspected everything. No signs of metal in the oil, so refilled with the recommended synthetic and the friction modifier, for posi. Then, drained the t-case and refilled with recommended Mercon (not Mercon V, as that's for tranny only). Then, finally, I went to the junk yard and removed a door, stripped it down and delivered it to their paint shop. They will paint the jam and then I will install, then they will paint/blend it to the rest of the truck. Still have to work on the dented part below the door. Today I'm gonna drive the truck 200 miles to Eugene and back, and also, hopefully pick up a free Suzuki TC185 basket case! Christmas comes early Update: drove the 200 miles well, no issues, and got my free TC185 basket case. Merry Christmas all!
1988 Kawasaki KLR250 1969 Honda Z50 silver tag 2002 Ford F-350 7.3 diesel 1975 Corvette 2017 Chevy Bolt “Throttle twisting geek” -LFN Last edited by Landsvw; 12-24-2016 at 10:36 AM. |
12-27-2016, 10:45 AM | #128 |
Drove to Eugene, had no issues! Then, yesterday, removed, cleaned and adjusted the throttlebody. Someone had messed with the butterfly valve set screw, so I realigned it best I could. It was idling a bit high I thought, so this may do it, or, may have to replace the tps. I'm assuming when original engine started to go south, somebody thought turning up the set screw was a good idea. Not supposed to mess with them, generally. But anyway, that's all I've done, besides drive it up to the snow line and shoot guns on Christmas Day. Tried out the 4x4 and that worked fine too.
Picked up a TC185 Suzuki from a nice guy that owns a brewery. Will be needing parts, so if anyone has a junker in the back yard, let me know. This one has a hole in the case, well, more than a hole, a giant crack and a hole where the chain broke and destroyed the left case. Also missing oil injection pump, and a few other odds and ends. I can get a case on eBay cheaply, but the oil pump and all the small parts are ridiculous in price.
12-27-2016, 11:59 AM | #129 | |
SUZUKI TC185 INFORMATION Suzuki TC185 A very practical all terrain motorcycle from Suzuki when announced in 1975. The 183cc two-stroke gave 16hp @ 7000 rpm, and with a dual range 5-speed gearbox, made a useful farm bike, and was used as such particularly in North America and Australia. Its lightweight, electric start and an incredible for that time 12000 mile 12 month warranty ensured sales for the TC125 Ranger, both with the recreational rider and those that bought for professional off-road use
12-27-2016, 12:04 PM | #130 | |
12-28-2016, 06:46 PM | #131 |
What year is the TC185? I miss my TS185 that I sold a couple years ago. I hope you find an injector, since you can't run without one. I would recommend www.suzukits.com, but it seems to have shut down. :(
12-28-2016, 06:48 PM | #132 |
Found it: http://suzukits.informe.com/portal.html
12-29-2016, 12:14 AM | #133 | |
12-29-2016, 01:33 PM | #134 |
These are the things missing that I can find so far, but, the PO thinks he has most of them somewhere in his shop...
Oil injection pump and hoses and bolts and cover Clutch rod Fuel petcock and bolts Chain guard and bolts Battery box bolts Regulator bolts and bracket? Starter solenoid Airbox and air filter assembly and bolts and boot Oil tank cap (broken) Tool holder and bolts Carb needle hold down item (under spring) Ignition switch bracket Generator brushes Fuel Tank strap Drive chain and link
12-31-2016, 05:34 PM | #135 |
You're welcome. I'm Weldangrind on that forum as well, although I'm not there often.
