#1216 | |
No. Blue is the fuel bowl drain screw. You use that if you won't ride the bike for a few weeks. With the petcock closed you can open the blue and drain out the gasoline so it does not dry and varnish the insides of the carburetor parts. Air/Fuel is hidden behind the aluminum welch plug. You need to drill it so you can get the tip of a screw to bite into the aluminum then pull/tap it out so you have access to the screw hidden under it. Air/Fuel is only for idle mixture adjustment. To get rid of lean you will need to rejet the carburetor to jets with bigger holes in them. While you have the carburetor open you might as well shim the needle as well. Check the Templar Resources Thread for details on that. https://www.chinariders.net/showthread.php?t=32177
#1218 | |
Here is information on the idle adjustment screw. It sets the slide height inside the tower on the carb https://www.chinariders.net/showpost...80&postcount=6 The black plastic sheath on the spark plug wire is on the outside of the sparkplug wire. It is just some additional insulation. That is normal. It is not physically attached to the spark plug wire... just over it. And here are a couple of posts on the carburetor and some other ifo on valves. https://www.chinariders.net/showpost...59&postcount=4 These posts are from the Templar resource thread at the top of the Dual Sport/Enduro section
#1219 |
Thumper,
thank you so much for the information. Your post on the rerouting throttle cable has saved my enthusiasm on the bike. It's a very nice bike and I can't wait for a warm day to take it for a ride. BTW, I have order a idle adjustment screw with big knob for placement. Thanks again, -Frank |
#1220 |
FYI for base Templar owners: If you install the large knob idle air screw it will hit the frame and turn while riding. Reported and confirmed over at the Facebook Templar/Titan group. I can attest that the stock idle air screw does rest firmly against the frame.
22 Templar 250 |
#1221 |
Bummer!
Many thanks for the head up, luckily it's not a too expensive approach. Hopefully someone (include myself) can come up with a mod to make it a manual instead of tool driven adjustment. -Frank |
#1222 |
You got a Templar X, right? The large knob works on the X (and M). It hits the frame on the base Templar. You should be fine, right???
#1223 |
I thought you had a Templar X? The base Templar has a different frame. On my base model I adjust the idle air with hemostats but needle nose pliers would work equally well. I wish I could use the large knob air screw.
22 Templar 250 |
#1224 |
That is a shame to hear. Everytime I start my Templar X first thing I do is I love playing with my large red knob
![]() I set it so the bike will idle on it's own with a cold start while I finish getting me helmet and gloves on. Then as I ride it after five minutes I'll usually tweak my large red knob down again so it idles normal for a hot running engine. I'm over sitting there for a minute or two holding the throttle and choke until I can let go and have it idle on it's own without stopping while I go finish getting geared up for a ride. I'll even take a picture if folks want to see it ![]()
#1225 | |
22 Templar 250 |
#1226 | |
#1227 |
Don’t get me wrong for anyone in future reading this that may not know, all carbureted engines from cars to motorcycles to airplanes and chainsaws and everything inbetween benefit from choke and/or a bit of throttle on cold starts until they warm up. Fuel sticks to cold engine intake parts robbing the engine combustion chamber of fuel making the engine run too lean to stay running on their own. With the choke giving more fuel to make up for the sticking fuel the cold engine no longer runs too lean but runs rich while cold. When the engine is hot the parts have expanded and the fuel is entering without sticking losses so the combustion chamber is now running richer with the extra fuel from the choke so it can now be released as well as anyone who was playing with their knobs or handgrips can reverse what they may have done when it was running cold as the engine can keep itself running now.
![]() ![]() PS don’t worry no photos of my large red knob, you’ll have to use your imagination for now.
#1228 |
Thank you very much folks, that was very educational. I'll report back once I get my large knob screw installed
![]() -Frank |
#1229 |
Don't forget to post pics!
22 Templar 250 |
#1230 |
Finally coming together
Well, I finally got some work done on the X
Carb, jetted, idle screw installed and cables routed properly. Seat cover changed. About half of the new graphics applied. Battery tray straightened and battery installed. Working on the bark busters. Still to do - get the skid plate fitted properly Finish the bark busters Finish the rest of the graphics Put some fuel in and start it up. |
