04-15-2011, 01:07 PM | #106 |
Good man Weld! Thanks for looking for us!
I don't need anything (now) and just for fun I sent an email to XY Canada to see how long it takes for them to ignore me. :wink: I came across a mechanically inclined fellow in Walla Walla who wanted a clean low mileage DRZ and he's interested in looking at my PP as a cheaper alternative. :idea: I also found a radiator shop who will repair my leak for $20-$30 so I should be good there as well . If I sell the bike I don't want the radiator repair to be temporary.
Happy to serve. |
04-15-2011, 11:25 PM | #107 |
Chinese radiators vs. Japanese radiators:
This is why Japanese bikes cost more. Because they're worth it! :roll: KLX rad head on. You can't even see it. It's compleatly protected from sones, debris, impact. Right rad. Bolted on tight with shock absorbing mounts. Armored. Hoses compleatly out of harms way. Left rad. Protected and easy to access and check overflow bottle. Now for the ChinaRad... Head on the fender provides some but not enough protection. Wide open and vunerable. Note the bolt holes to mount a cover/screen, but nothing it there... You can see some damage already. Impossible to access catch bottle. There are actually two of them. Both are opaque, and require removal of bodywork to check. Note China Ziptie... Skid plate needs improvement. NOTE I am not bashing here, I dig this bike . Just pointing out the way the Chinese do things to save money. These are opportunities for the individual owner to improve the bike, and personalize it, and save thousands of dollars. :P
Happy to serve. |
04-15-2011, 11:55 PM | #108 |
Thank you for taking the time to post the photographs, and explain the differences, Doc. Indeed, the Chinese do an excellent job copying/manufacturing the small displacement, air cooled engines. However, once you add water cooling, or a hybrid engine design, the motorcycle becomes more complex, and the opportunities for failure increase.
04-16-2011, 01:38 AM | #109 |
Doc, the good news is that the rad has a huge frontal area, which means it will be very effective at cooling. As well, the threaded inserts are a nice touch; it will be very easy to add either perforated aluminum or stainless expanded metal (your choice, but perforated aluminum is lighter).
Most skidplates are complex, but yours will be simple to replicate. I'd use a solid piece of aluminum, heat and bend it as necessary and then drill holes to lighten it.
04-16-2011, 12:15 PM | #110 |
I'm at work now with antifreeze on my left ass cheek of my jeans and my left shoe and pants leg. :evil:
I think the upper hose is leaking at the raditor. I will stop at the parts store on the way home and try to find some hose that matches up. FOR ALL PP400 OWWNERS: Don't go by how your hoses look. Mine looked fine. Repalce them. They suck even new. I'll fill the radfiator bfore I go home and it's only a 7 mile ride I should be fine but will watch the gauge. Chinabikes. :roll:
Happy to serve. |
04-16-2011, 02:34 PM | #111 | |
04-16-2011, 02:50 PM | #112 |
This would be a better bike to buy used from a responsable owner who shook out the bugs rather than buy new. After I have this bike a while it will be a real winner. Now it has real potential.
Happy to serve. |
04-16-2011, 02:51 PM | #113 |
Not once did Q leak antifreeze on me and I never once changed it's coolant. :wink:
Happy to serve. |
04-16-2011, 02:52 PM | #114 |
I hope the autoparts store will have a correct diameter hose.
Happy to serve. |
04-16-2011, 04:56 PM | #115 |
Project stalled. Bike out of commission. :evil:
It uses 3/4" heater hose but the bends are too sharp. Also the chinaclamps won't hold. I'm off to the store again for new USA clamps and hopefully some 90 degree elbows. I don't think it was the radiator leaking but one of the hose connections although with it all apart I STILL can't find the leak... I have officially been hurt by The Ring. BTW 4 feet of quality heater hose? $36! 8O
Happy to serve. |
04-16-2011, 05:36 PM | #116 |
Probably cheaper than the Yamaha or Honda equivalent. :roll:
Try some copper elbows, like Kato recommended. As well, t-bolt clamps are excellent for such things; look for them at a plumbing supply shop that carries irrigation stuff.
04-16-2011, 05:50 PM | #117 |
Just got back from the parts store. They had elbows made for the 3/4" heater hose and I bought some good clamps. Project is back. It's SUNNY AND WARM I wanna ride this turkey!
Happy to serve. |
04-16-2011, 06:43 PM | #118 |
pp400
please let me know what you come up with.
2015 zongshen rx3,,(Sold),,,2016 bashan storm,,2005 Harley ultra classic. |
04-16-2011, 06:58 PM | #119 | |
04-16-2011, 07:22 PM | #120 |
Hoses replaced run up and checked for leaks. Looks good. Back together I'm going for a ride!!!
Happy to serve. |
