12-16-2010, 04:03 PM | #106 |
THANK YOU!!!!!
I am grateful. PM sent. Just so other members know, the prices of the parts are VERY reasonable! :P
Happy to serve. |
12-16-2010, 06:33 PM | #107 | |
12-24-2010, 06:43 PM | #108 |
UPDATE:
SpudParts arrived today. Still not running. I replaced the CDI. No improvement. I replaced the coil, same result. I have the old stator and pickup units out and the new ones installed. I don't have time to button it up yet but lets pray this was the problem!
Happy to serve. |
12-24-2010, 07:45 PM | #109 | |
12-24-2010, 09:28 PM | #110 |
I just got back form church. I may try to put the cover on before visiting friends.
Once they got started, The Zong Cube People shipped the parts very fast. The quality and price of the parts was amazing, and the books are useful too, although a bit difficult to follow being in 'Chinglish' :P
Happy to serve. |
12-25-2010, 01:52 PM | #111 | |
Anyone contemplating buying a Chinese motorcycle should be aware that getting Chinese parts is going to be more difficult than obtaining Japanese parts. The Japanese motorcycle manufacturers have an extensive, global support network unrivaled by even the European manufacturers, let alone the Chinese. However, if you are willing to exercise patience, and persistence, you can get high quality, reasonably priced parts from Zongshen America. Qlink seems to offer faster service than Zongshen America, but QLink also appears to charge much higher, Japanese prices for their parts. Spud
12-25-2010, 10:17 PM | #112 |
Another update.
The Zong continues to defy me. New stator, coil, CDI, plug, cleaned and checked the carb, changed the oil, set the valves and still no joy. No sign of life at all. Comparing the spark to Q it is still not as strong but I don't know if that's the problem. I didn't check it's compression but I can't imagine a bike with so few miles could not have compression. I just don't know. Anyone got $200 for a project?
Happy to serve. |
12-26-2010, 07:53 AM | #113 |
Dont give up. We just need to troubleshoot.
12-26-2010, 12:45 PM | #114 |
My first thought before the coffee kicks in is to check each wire from the stator for continuity.
12-26-2010, 12:46 PM | #115 |
Don't give up, Doc; I'm sure we can figure things out. For starters, I would certainly check the compression to eliminate it as one of the potential problems. For the engine to work we need spark, fuel, and air (along with compression, proper timing, et cetera). After replacing all the components in the electrical system it appears the spark is fine; perhaps it is time to look for problems elsewhere.
12-26-2010, 04:22 PM | #116 | |
Many moons ago at a part-time job: I had a customer bring in a lawnmower that would not start. We tried everything you've done, so far. We had spark. Good compression, Gas and starting fluid...no luck. Finally pulled the muffler it was built around the shaft and found a dirt dobber nest clogging the exhaust port??? 8O Bill R |
12-27-2010, 08:12 PM | #117 |
Doc,
I believe you have replaced the stator, pickup coil, CDI unit, ignition coil, and spark plug. If weak spark is indeed the problem, it might be caused by the following items. Spark plug dirty, broken, or maladjusted: Try another new, NGK spark plug, and make sure the gap is correct. Spark plug cap or high tension wiring trouble: I believe your new ignition coil included a new spark plug cap and high tension wire. Spark plug cap shorted or not in good contact: Perhaps you have a bad electrical ground in your wiring system? If you don't have a bad electrical ground, Zongshen might have sent you a bad CDI unit. If your electrical ground is good, and your problem is indeed caused by a weak spark, I suspect you got a defective CDI unit from Zongshen. :roll: Have you had a chance to check the cylinder compression? Spud
12-27-2010, 08:14 PM | #118 | ||
This bike sat in an orchard under an awning, covered for a year. Who knows what nested where in it. BUT it was parked because it dies when the prior owner was riding it, so whatever is wrong also must include some mechanical failure.
Happy to serve. |
12-27-2010, 08:18 PM | #119 | |
The new coil had a wire and cap. I also tried a Hondoid/Lifan new coil/wire/cap. Same weak spark. Switching between the new and old CDI makes no perceptable change, weak spark. I removed the coils ground wire and used a grinding stone on a drill to expose bare metal, no paint, and reinstalled the ground wire. No joy. I've not checked compression. I don't have an adapter that will fit but I can do the old tumb test Brother Dan talks about in his online motorcycle course. I've not worked on the bike for a couple of days since my last post. Im on Frustration Vacation. Maybe tomorrow.
Happy to serve. |
12-27-2010, 08:32 PM | #120 | ||
