Old 01-22-2011, 01:20 PM   #106
Well to my amazement I got my wire connectors today but I doubt I'll get anything done, just havnt been up to doing to much the last couple of days.
I'll get out there sunday and get a few things done on the electrical.
Old 01-23-2011, 05:04 PM   #107
Rode it.....I just came in from taking it for a little ride around the yard.
Its still not all put together, fenders and such but it is running although not perfectly smooth, I'm guessing I'll need to clean the carb and double check the wiring for loose connections.
But anyway the thing rocks even though I have no traction on the ice out in the yard it seems to have very good final ratio.
I'll know when I take it down the road if it tops out to soon or cant pull 5th.
I may have to hook up a clutch safety switch because having to go back to neutral to start it is going to drive me nuts.
EDIT:Heres a vid---a lousy vid and it was cold outside (13F)
Old 01-23-2011, 09:16 PM   #108
Jim   Jim is offline
Congrats, looks like you had some fun with it
"Be excellent to each other"
Old 01-23-2011, 11:33 PM   #109
TeamCheap, you just made my day! That's exactly what I would have been doing today if I had it my way.
Old 01-24-2011, 06:23 AM   #110
Thanks.
I wasnt sure if I would even get this far since I sat in the house thursday, friday and saturday, just wasnt up to going out and working on it or doing much of anything.
Sunday I dragged myself out there and got some stuff done and I love the "vintage connectors" kits I bought although I feel they are a bit over priced.
The quad does run but not quit right so I'll start looking it over to see whats up.It may be the intake manifold or gunk in the carb or an electrical issue.
I'm really leaning hard towards a clutch switch so I can start it in gear if I want to, if I do that I'll need to wire in a diode to keep the neutral light from lighting everytime the clutch is pulled. :roll:
Old 01-26-2011, 06:55 PM   #111
Ok so I took the carb off and yes there was some gunk and crud in there.
I cleaned it up and put it back together but didnt have a small filter so I have to get one but it was running much better.
Now it idles for a minute or so then will increase rpms for 15-20 seconds then idle back down all on its own.
I was just sitting on it for a few minutes listening to it cycle.
Before cleaning it it ran OK but was very inconsistant and stalled easy now atleast it is very consistant and stays running just surging a bit.
I dont tlike that tiny O-ring between the carb and intake manifold so I'll look for a replacement.
Old 01-26-2011, 08:16 PM   #112
I dont like that tiny O-ring between the carb and intake manifold so I'll look for a replacement.
That's a good idea because it seems to me your idle problem is a vacuum leak.
Old 01-26-2011, 10:09 PM   #113
My guess is the o-ring between the intake tube and the head is the culprit.
See this thread for details, page four: http://www.chinariders.net/modules.p...r=asc&start=45
Old 01-27-2011, 04:36 AM   #114
Yeah I had seen that post and was thinking about that when I was looking at that tiny, thin O-ring.
I'll get a positive seal there and hopefully that will be it but it could be the intake manifold I made thats leaking somewhere.
Ohh well its not to bad right now and is very rideable and fun even with the over inflated tires on the ice and snow with next to zero traction it still spins the tires like mad and gets going.
Old 01-27-2011, 07:22 AM   #115
ejcycles's Avatar
TC
Suggestion... Leave the O-Ring, add a gasket & T1194 {from 3-Bond} that will seal any leak @ that point. I had an old 1978 Honda XL100 I rebuilt for a guy, had issues with vacuum leaks @ carburetor-n-manifold & manifold & head. I added a gasket & T1194, done no more vacuum leaks.
Old 01-27-2011, 02:15 PM   #116
Permatex also makes an outstanding sticky slimy sealant.
Old 01-27-2011, 07:28 PM   #117
Thanks for the suggestions.
I'll work on it this saturday and put a gasket and T1194 on it.
Had a long day at work today changing a 12" valve.
Old 01-27-2011, 08:11 PM   #118
midlifekrisiz   midlifekrisiz is offline
i am leaning towards a loose nut near the fuel tank....
Old 01-27-2011, 09:38 PM   #119
If that means the operator, you might be right.
Old 01-27-2011, 10:20 PM   #120
Jim   Jim is offline
Reminds me of some song lyrics.
What is the most important part of an automobile? An old timer once told me it's the nut that holds the wheel.
