Old 01-21-2018, 07:25 AM   #106
Update on the oil cooler. Yesterday I added a second oil cooler thanks to Megadan for sending his extra cooler he had. I had to notch the 1/8" x 1" aluminum angle to clear the header pipe. Also had to relocate the horn. It was a tight fit but got it all to fit. Now I have a matching set. just about the time I got it all finished it started to rain so no road test. Should have some good riding weather today.
2004 Honda ST 1300
Old 01-21-2018, 01:38 PM   #107
Did you end up cutting the factory horn mount tab off the down tube?
Old 01-21-2018, 04:23 PM   #108
No i left it on. It didn't interfere with the angle or cooler. I mounted the horn to the cooler. I had to extend the wires though.
2004 Honda ST 1300
Old 01-22-2018, 01:55 AM   #109
That was exactly the area I had contemplated putting the horn. It was either that, or between the two coolers on the downtube.
Hopefully the extra hoses actually came in handy. Did you end up cutting one down to link the coolers together?
Old 01-22-2018, 08:00 AM   #110
The connectors are different sizes on each end of the hose so I had to rob a connector off one hose and cut one hose to make shorter. Thanks again. I did get a chance to take a long ride Sunday morning but it got too windy. Roads were still damp from the rain and I was getting pushed around by gust of wind so I kept to the back roads and just cruised around at 45 to 50 mph till about noon. I was hoping for the winds to die down after lunch to go for another ride but that never happen. I really need to tune the carb a little. It may be time to upgrade the carb. I think my pilot jet may be a tad too small now. 120 Main jet was running a little lean but I think the 125 may be too rich. I didn't get to try it. Anyway I was happy just getting some ride time in.
2004 Honda ST 1300
Old 01-22-2018, 01:51 PM   #111
The constant weather fluctuations at this time of the year make it hard to really dial in a carb too. Thinking of switching to the "Mikuni" clone?
Old 01-22-2018, 03:07 PM   #112
We are back to our typical warm, humid and muggy weather. It would of been a good day to tune it. The wind was not cooperating. It was a little to dangerous to do any high speed testing and tuning. If I can't get the stock carb dialed in I'll get Mikuni Clone. There's has to be a better way of adjusting the idle mixture without having to pull the carb off. I think it may be a little off too. I don't know when I'll have time because the next few weeks are going to be busy. The fabricator emailed me this morning that the skid plates are ready to be picked up (don't know why he didn't let me know on Friday they were ready), It's Mardi Gras time and I'm booked up for the next two weekends and Mardi Gras day DJing on a few parade floats. Way too many irons in the fire.
2004 Honda ST 1300
Old 01-22-2018, 04:13 PM   #113
Not a cheap option, but very handy for carbs that have the idle mixture in this location (Honda...)
https://www.amazon.com/Motion-Pro-08...35JBN74AYYGGNT
You may or may not have to file the tip down to a size that will work with this carbs mixture screw slot,
They have an even more expensive one that uses hex bits and fits in even tighter areas. https://www.amazon.com/Motion-Pro-08...9S41KNHW1M72ZQ
At almost $70 though...
Old 01-22-2018, 04:27 PM   #114
I may have to get the less expensive version but looks like that's the ticket. Now the idle screw on my 200x stuck out far enough that all I had to do was slip a piece of vacuum hose or small fuel line over the end of the screw and used it like an extension. I do the same with my weed eater and chainsaw carbs.
So much easier than trying to adjust with a screwdriver with a little motor that's vibrating all over the place. I looked at getting one like this. https://www.amazon.com/Racing-Produc...1031XH735454HC
2004 Honda ST 1300
Old 01-24-2018, 10:43 AM   #115
kirbo7106's Avatar
[QUOTE= It's Mardi Gras time and I'm booked up for the next two weekends and Mardi Gras day DJing on a few parade floats. [/QUOTE]
Don’t be getting too crazy out there JerryHawk250! BUT if you end up on the news...send us a link!
Dan-O
-2018 Tao Tao HellCat - DOA
Old 01-24-2018, 12:54 PM   #116
I'll be on the float watching all crazy people. You do see some crazy stuff on the parade routes. I'll have the camera rolling to whole route.
2004 Honda ST 1300
Old 02-06-2018, 04:37 AM   #117
istoleyourtoys   istoleyourtoys is offline
istoleyourtoys's Avatar
Silver thing around Exhaust what is it?
Whats that silver thing around your exhaust ?
Old 02-06-2018, 07:33 AM   #118
Exhaust clamp. Or are you talking about the horn? I had t relocate it due to the having to make room for the second cooler.
2004 Honda ST 1300
Old 04-16-2018, 05:40 PM   #119
redneck51587   redneck51587 is offline
redneck51587's Avatar
Thanks . No I got it on taobao.com $54 and some change delivered. I originally ordered with a stack plate cooler but was out of stock. https://world.taobao.com/item/254075...?fromSite=main
How do you order from this site if you can't read chinese?? Asking for a friend... LOL
Old 04-16-2018, 05:46 PM   #120
Open with Google Chrome. It will translate it for you.
2004 Honda ST 1300
