#106 |
I bought one just minutes ago Lmfao! Will just keep the other LED bulb I bought as a backup.
On a side note, I'm REALLY excited now! ![]() ![]()
![]() Rides a 2016 Bashan 18C with Blue PlastiDip, piped and jetted, USB charger, real-time digital volt meter, faux carbon fiber handguards, 5 COB led headlight upgrade, auxiliary led light bars, and an MSR shift lever with new grips, T6 aluminum handlebars anodized in blue, polished handlebar brace, decals, HD Unibear chain and spoke covers waiting on the always-full mod shelf...... |
#107 |
That looks good. your doing all the plastics I assume ? Have you taken the stickers off or just painting over them ?
2016 Green Bashan Brozz. |
#108 |
Just painting over them , Kip. If there's ever a day I want to return to "stock", the PlastiDip will peel right off them.
#109 |
More toys showed up today......currently waiting for the BT unit to charge so I can pair it with my phone.
#110 |
Oh, and just a public service announcement:
During tonight's mission amidst "operation plastidip", I realized that whomever designed the rear of the Brozz needs a kick in the balls. Seriously. The ass-end of these bikes could have been designed SO much better.... ![]()
#111 |
What's the problem with the rear?
#112 |
The way the tail section's plastics are integrated with the rear grab handles, plus how the rear harness feeds THROUGH it....this was a total pain in the nuts trying to disassemble it without scratching the paint on the grab handle assembly. Getting it back together withOUT trashing a newly painted PlastiDip part will require 2 guys each sporting 3 elbows LoL
#113 | |
#114 |
Forgot to post this: I got the valves readjusted, tossed in an NGK, and cut off them hideous reflectors in the back....
#115 | |
Did you adjust your valves before you started it for the first time or are you just now doing them ? How far off were they ? Mine were very tight right out of the crate
#116 |
I adjusted the vales on mine before I ever fired it up. They were way tight under .002 inch on both.
2016 Brozz |
#117 |
This was the second time, just trying to be on the safe side. Outta the crate mine were tight as hell. Initially I had set them to 3 and 4. This time, I set them to 2 and 3. Still room enough, yet a fraction easier on the tappets
#118 |
Look what just showed up!
![]() ![]() Oh, and the headlight, too ![]() ![]()
#120 | |
