Old 10-19-2017, 08:15 PM   #106
sjeff35   sjeff35 is offline
Originally Posted by Jay In Milpitas View Post
I whole-heartedly recommend that you Loc-tite the *shirt* out of that bolt.
I was thinking the same thing. I'm breaking out the "RED" for this one
Old 10-19-2017, 09:08 PM   #107
Couple of days ago the "screw" that you put into the bottom of the bikes frame to hold the spring retainer on to the bike popped out when I put the bike on the center-stand. Luckily it was in my garage so the screw, retainer and spring were easy to find. Since it's a screw and barely holds itself in the bike I decided to mix up some epoxy to hold it in. Works great! Don't ever see a reason to remove it.
FYI
Joe
2017 BMW F800GS Adventure
Old 10-19-2017, 09:19 PM   #108
Originally Posted by sjeff35 View Post
Hope I'm not hijacking the thread, but I ordered a center stand along with my bike. I tried to put it on the other day and had the same problem that other's have had. The groves in the shaft are not spaced out properly. I was following the instructions on the CSC site.
Then it struck me as to why it had been drilled and tapped and they included a washer and bolt on one end.
I'm guessing this is their fix. So you only use a clip on one side???
I'll try to put this back on after work today and see what happens.
only thing harley davidson makes in the us is the motor cases.
2016 hawk
kaw h1 400 tripple
13' long chopper in progress
2009 johnny pag bar hog
Old 10-19-2017, 09:22 PM   #109
Originally Posted by jbfla View Post
2.0 generation of the centerstand.
The top ends were pre-ground.
After reading the CSC tutorial, the installation took about 10 minutes.
I was a concerned about lifting the bike onto the stand because I also have the lowering link installed.
And because of some health issues, I have lost a lot of the strength I once had.
On the first attempt, I couldn't do it.
Then rolled a 3/4" board under the rear wheel, and gave a grunt...
On the second attempt, besides adding the board under the rear wheel,
I altered my holding and lifting technique. The bike popped up on the stand.
I had to keep an eye on the front handlebars. They kept wanting to flop to the side.
A few concerns:
....ground clearance...
.....and for off road riders, maybe a way to snag a branch or rock???
....make sure the kick stand is down before taking the bike off the center stand.
....and maybe a warning for those working around the bike when it is on the center stand...
...it only took a slight nudge for the bike to roll forward off the stand.
jb
this is why you should upload your pics directly to chinariders forum!
2016 hawk
kaw h1 400 tripple
Old 10-19-2017, 09:26 PM   #110
huh???
