10-26-2019, 08:08 PM | #106 | |
Blue white strip + of pickup Green white strip - of pick up The blue white goes to CDI left too the green white below it Center CDI too is to coil below it is earth 2 pin plug top is kill switch or same as coil Bottom is black 12v dc or if AC CDI it’s from stator red white stripe |
10-27-2019, 02:14 PM | #107 |
Well its in and running. Video link above. I think there is an issue though. Maybe you can help me confirm it for now. Im waiting on a new rear sprocket and chain because this engine requires the use of a 520 sprocket and chain. The shaft keyway is slightly larger. Anyway, I think the clutch might not be working. When i pull in the clutch the engine sprocket continues to turn, even if I try and stop it with my foot. Also the clutch handlebar lever feels too easy to pull compared to the hawk. Obviously without the chain connected I cant say for sure but I think it may be not working. I disconnected the cable and am manually moving the clutch lever on the case and same result. I have no idea what clutch is in this thing and have no idea where to start. If anyone has any advice Id appreciate it.
2019 Hawk 250 My Hawk 250 playlist on my Youtube Channelhttps://www.youtube.com/playlist?lis...DWieLoSSddYvWk |
10-27-2019, 02:23 PM | #108 | |
10-27-2019, 02:25 PM | #109 |
sounds good. I think it will be okay. Clutch plates are probably just dragging and need to wear in place.
10-27-2019, 02:30 PM | #110 |
Thank you both. Im hoping it will work itself out once its all together. We will see.
10-27-2019, 03:05 PM | #111 |
That is awesome!! Congratulations and great job. I agree with others, clutch plates are probably just stuck. I think you will be ok.
2019 Bashan Brozz 250 2019 Honda Africa Twin CRF1000L |
10-29-2019, 09:34 AM | #112 |
Are you planning on gutting the cat or a free flowing exhaust?
10-29-2019, 09:48 AM | #113 |
Yes. Already done.
10-31-2019, 07:35 PM | #114 |
Well unfortunately after getting the new sprocket and chain on and trying to break it free, the clutch is still stuck "off" or engaged however you want to say it so I guess Im going to have to drain my brand new oil and remove the side cover tomorrow and see whats going on. Hopefully nothing major. 🤬
11-01-2019, 11:52 AM | #116 |
https://i.imgur.com/NWS79Th.jpg
https://i.imgur.com/ohbDcCp.jpg Here is the clutch. Anyone know what kind it is? Im looking for torque specs on the pressure plate bolts. I know nothing about motorcycle clutches. Nothing obviously wrong to me. I was able to free up the plates. Requires a special tool? I do Not have to remove the clutch. I think its like a Honda.
11-01-2019, 12:04 PM | #117 |
move the clutch lever and see if the plates release, maybe they forgot the pushrod.
11-01-2019, 01:05 PM | #118 |
Looks like everything is there. You have a picture of the inside the cover? Like to see if everything is in place on the clutch lever.
Pressure plate bolt should be 9 lbf·ft. Tighten the lifter plate bolts in a crisscross pattern in several steps.
11-01-2019, 01:17 PM | #119 |
I made sure the discs werent seized, oiled everything and I put it all back together and it still doesnt work. Something is wrong with the whole thing. The lever just doesnt feel right. Im getting very frustrated. I even took apart the Hawk CG engine to compare and everything looks the same. The Hawk has a better 7 plate clutch stock though vs the 6 disc in the loncin. Ill try to get another pic of the case when i take it apart again.......
11-01-2019, 01:20 PM | #120 |
So when you start the bike it just tries to take off when you put it in gear?
