Old 05-28-2013, 09:58 PM   #106
Corvairkid   Corvairkid is offline
Corvairkid's Avatar
10 at night just now getting off work............ all my roommates are gone and the naiborges are gone for the summer time to get to work!!!!
Old 05-28-2013, 10:04 PM   #107
Corvairkid's Avatar
the new cdi box's look like this
ID:	132   Click image for larger version
Old 05-28-2013, 10:34 PM   #108
Corvairkid's Avatar
I got spark!!!!!!!
Old 05-28-2013, 10:41 PM   #109
Excellent! I'm glad you verified your ZS250GS employs an AC-CDI unit. I wonder if anyone has an accurate wiring diagram for this bike? The only wiring diagram I found for the ZS250GS shows the bike using a DC-CDI unit.
Old 05-28-2013, 11:20 PM   #110
Corvairkid's Avatar
WELL STILL not running =( little poofs of white smoke but no real bang or kick not even a stumble..
Old 05-28-2013, 11:35 PM   #111
bogieboy's Avatar
smokes coming from the exhaust right? LOL thats a good sign, youre getting close....
Old 05-28-2013, 11:37 PM   #112
Corvairkid's Avatar
yep now i think my issues ib the carb i'm taking it off and checking for fuel flow 11:37pm
Old 05-28-2013, 11:56 PM   #113
bogieboy's Avatar
have you tried starter fluid? would be a good indicator if it pops over on starter fluid that theres a carb issue...
Old 05-29-2013, 12:04 AM   #114
Corvairkid's Avatar
no i dont have any but i primed the chamber with some gas and put the plug back in as well as shot some fule in to the intake side and got nothing but its late and i might be missing something ill see in the morning its shower time and food time i'm es-static (yes pun intended) and shocked (again) to have spark back!
Old 05-29-2013, 12:09 AM   #115
bogieboy's Avatar
real punny...
Old 05-29-2013, 12:09 AM   #116
Now that you have spark, the problem must reside in one of these other areas.
Compression
Air
Fuel
I suggest you check compression first. If compression is low, check the valve lash before you check elsewhere.
Old 05-29-2013, 12:16 AM   #117
Corvairkid's Avatar
will do i'll have to get some fellers
Old 05-29-2013, 12:26 AM   #118
I use these feeler gauges, which I bought from Harbor Freight.
http://www.harborfreight.com/32-piec...uge-32214.html
The valve lash for your ZS250GS is probably the same as for my Zong.
http://www.chinariders.net/showthread.php?t=4539
Old 05-29-2013, 12:30 AM   #119
Corvairkid's Avatar
just looked at them and a Compression tester doe 20 bucks... any luck with them?
Old 05-29-2013, 12:33 AM   #120
Yes, I also own the Harbor Freight Compression Tester. It does a good job.
http://www.harborfreight.com/quick-c...ter-95187.html
You might enjoy reading the following thread.
http://www.chinariders.net/showthread.php?t=5298
