01-17-2023, 08:59 PM | #1051 |
Mine measures 3/16" ID and 3/8" OD
01-17-2023, 10:40 PM | #1052 | |
Basically, you run next to the bike and then hop on it and pop the clutch. If you're short, that might be easier said than done on a tall dirt bike. OR: Keep a small battery back-up jump pack with you on long adventure runs. They're small and would easily jump start your bike. Better than a kick starter for sure. |
01-17-2023, 10:50 PM | #1053 | |
Thinking this battery is a good choice. I'm interested in what did you finally land on for Carb jetting. I've cracked the OEM carb as you first did on this forum.Thinking about adding a air screw from another post. My only complaint is setting a preferred lower idle. Searching now near 90 pages of information I cant seem to easily find what I'm looking for. |
01-18-2023, 12:00 AM | #1054 | |
Not sure if I should try adjusting the valves or rejetting the carb as my next step. I haven't been able to find detailed walkthrough or video on adjusting the valves on this specific bike so I am a bit apprehensive. I also understand the carb rejetting requires grinding of the bolt heads in order to get into it. Also makes me nervous. Any input on best bang for my buck here? What's easier and/or the most likely culprit? Or should I be checking something else entirely? BTW, it's not leaking gas anymore either... At least it didn't all day after I got it running. I will check and verify tomorrow morning... Thanks again for all the assistance!!! |
01-18-2023, 07:50 AM | #1055 | |
2022 X-Pro Templar X 250 “Rocinante” 2022 X-Pro Bolt 125cc “Dapple” 2022 Royal Enfield Interceptor 650 “Traveller” 2023 Royal Enfield Classic 350 “Trigger” |
01-18-2023, 08:55 AM | #1056 |
Thats a great idea, there are already technical specs threads for the Hawk and Brozz, would be useful for the TempX
01-18-2023, 09:16 AM | #1057 |
I try to place part numbers/pics and photos in my dedicated threads in the videos and pics section. Sometimes people start side tangents that clutter them. But I often refer to those threads with links in the main 1000+ thread (this one). For now, that is the best I can do. If you start yet another thread, people will post side tangents anyway, and it will get filled with clutter. It is just the nature of forums
01-18-2023, 09:19 AM | #1058 |
True, but the very first post would be the collection of data/part #s/torque specs, etc that would be a running list.. that way the clutter would be subsequent posts but all the info needs to be maintained in the first post
ex: https://www.chinariders.net/showthread.php?t=15942
01-18-2023, 09:29 AM | #1059 |
It could also have links to our existing posts, like the ones I have concentrated in my dedicated threads in the video and pics section, and there are lots of them hidden in this main 1000+ thread. The search function just doesn't work. I get zero results often when I know that I am using the right search term and member name, like a specific tire name, or part. Even if you select what to search (titles or full threads, etc). I don't know why the search function fails so miserably. But that's why having dedicated threads helps.
01-18-2023, 09:35 AM | #1060 |
For sure.. when all else fails I just do a Google search for what I'm after and append "chinariders.net" to the search like recently when I was searching for brake pads for the Brozz
01-18-2023, 09:03 PM | #1061 |
like ...what about the panniers? Please advise.
arkansas |
01-18-2023, 10:05 PM | #1062 |
FYI, that luggage rack is on a Templar motorcycle like ours (X model) that is sold on Alibaba. The luggage rack itself is currently NOT available separately on Alibaba.
We have asked PSM whether they would offer the racks, and they responded positively, maybe two months ago, but the rack has not showed up on their website. If you want to buy that rack, join the few people that have contacted PSM and asked for a part number, and offered to buy the rack if it becomes available. Only persistent requests might get PSM to order some of them from Zumaav. But they are unlikely to order any if there is insufficient interest. |
01-19-2023, 08:07 AM | #1063 | |
01-19-2023, 10:14 PM | #1064 | |
Looked at it, thinking dang this is a lot smaller than I thought it would be…because it’s the 4XL (50 CCA) not the 5XL (80 CCA). *sigh* Double checked my order, it was for the 5XL so I got the one in a million wrong part from Amazon. Y’all think 50 CCA is enough for this bike?
01-19-2023, 10:39 PM | #1065 |
Amazons easy to return stuff. I think my wife returns half what she buys on there. Just go to orders and returns and follow the steps.
22 Templar X 250 Hand Guards Custom Graphics Pro Taper Grips 125 main 45 pilot jets 42 tooth rear sprocket 2010 Yamaha Vstar 1100 Silver Star |
