Old 05-29-2017, 07:55 AM   #91
Yes! I remember you posted this before. Jerry, you need to do a redux on your plate. It would certanily support the bike. And check out all the weight reducing holes.
I was going to drill all the pretty holes and thought about defeating the whole purpose I was putting the skid plate on in the first place. With the luck I have the first ride out on a trail a branch will pass right through one of those holes and shish kabob the oil hose. Besides when I go to fry an egg it will run through the holes. Man after looking at the picture I just realized I never washed the bike from the last trip I made. Too many irons in the fire including the skillet skid plate .
2004 Honda ST 1300
Old 05-29-2017, 09:10 AM   #92
kirbo7106's Avatar
Skillet Skid Plate!
JerryHawk250 you have just named your creation! You should patent that name!
Dan-O
-2018 Tao Tao HellCat - DOA
Old 05-29-2017, 09:34 AM   #93
LOL. I do plan on extending the sides out more and do something similar to what Chuck did. First I wanted to do something simple to show the average guy who don't have Welders or welding skills can do. All that was needed was a grinder, jigsaw and drill. You can go to any fabrication shop and have them cut you a piece to size for little or no money. I have all the tools equipment, Welding machine and skills to make something more complicated. Aluminum could be used instead but will have to be careful not to Crack the aluminum when making sharp bends.
2004 Honda ST 1300
Old 05-29-2017, 11:19 PM   #94
MDStroup   MDStroup is offline
MDStroup's Avatar
Thanks . No I got it on taobao.com $54 and some change delivered. I originally ordered with a stack plate cooler but was out of stock. https://world.taobao.com/item/254075...?fromSite=main
Do you have the link to the version of the oil cooler with the stacked plate cooler?
Also, did any one else have a problem having the page from the link no translating?
Old 05-30-2017, 08:11 AM   #95
Contact mjstef hawkclusters@gmail.com for the stack plate. He has the valve cover kit with the stack plate cooler and I think he is working on getting the oil screen version like my kit with the stack plate too.
View the TaoBao site with Google Chrome to translate it.
2004 Honda ST 1300
Old 05-30-2017, 12:18 PM   #96
Aluminum is much easier if you anneal it first. All it takes is a bar of soap and a propane torch. Google is your friend.
Old 05-30-2017, 01:04 PM   #97
Thanks for the info. I may remake it in aluminum later on. I was thinking I would have to do some welding was the main reason I went with steel. My welder is set up for stainless and steel right now and didn't want to have to set everything back up for aluminum. I have lots of aluminum wire but no shield gas.
2004 Honda ST 1300
Old 06-01-2017, 01:19 PM   #98
MDStroup's Avatar
Thanks.
All i use on this PC is chrome and every time i translated it it would stay the same.
Old 06-01-2017, 01:31 PM   #99
Thanks.
It will only translate the text. Anything that is in a picture will not translate.
2004 Honda ST 1300
Old 06-01-2017, 02:17 PM   #100
humanbeing's Avatar
... in a picture will not translate.
https://support.google.com/translate.../6142483?hl=en
Old 06-01-2017, 02:31 PM   #101
Originally Posted by humanbeing View Post
Did not know that. Thanks.
2004 Honda ST 1300
Old 06-02-2017, 12:04 PM   #102
Dwake402   Dwake402 is offline
How does oil flow through this
Old 06-02-2017, 01:10 PM   #103
The oil pump sucks it threw the oil line and cooler then returns back to the base.
2004 Honda ST 1300
Old 06-03-2017, 05:53 AM   #104
MDStroup's Avatar
I guess i will take a screen shot later and post it. Nothing will translate. Not one word anywhere one the page.
Old 06-03-2017, 08:26 AM   #105
You may need to update chrome or just use a different pc.
2004 Honda ST 1300
