05-19-2015, 02:45 PM | #91 |
wire color schematics
For those of you that have done a successful install, are the colored wires as follows: white--low beam, blue--hi beam, and green--ground? I have mine installed this way and "lighty no worky." I do have a rect/reg wired in single phase with all instrument grounds isolated to the neg (-) side of the battery only. Only the rect/reg is grounded to the frame (one of the yellow wires coming from it, other yellow goes to stator). Maybe it is just a bad bulb, just my luck as always. Thanks and appreciate any help.
Kirk |
05-19-2015, 02:51 PM | #92 |
Welcome, we are glad you joined us. I'm sorry to hear you are having problems with the LED installation.
Yes, the wires coming from the LED bulb are color coded in this manner. Blue: High Beam White: Low Beam Green: Ground
08-13-2015, 01:14 AM | #93 |
Found a "wiredo" rec for AC lighting bike http://item.taobao.com/item.htm?id=22211028618 | Reseller explained more clearly http://item.taobao.com/item.htm?id=39272228687
--- Get some extra 6.3 female connector if the old one don't matches NEW reg ...
08-26-2015, 12:16 AM | #94 | |
Hector Mountrack Vento 2006 |
08-26-2015, 12:24 AM | #95 |
No, I don't know the wattage output of the ZS200GY-2 stator.
08-26-2015, 09:51 AM | #96 |
I bought similar bulbs for my bike, they are not the exact same design, but the light output is quite supurb.... here's the lowbeam at 50 yds at night...
and here is the highbeam frim the same distance... and here is the bulb I used... http://pages.ebay.com/link/?nav=item...909066&alt=web |
08-26-2015, 01:15 PM | #97 |
Thanks for posting the update.
That is the shorter, compact version of the original bulb. I just installed the same LED bulb, from another manufacturer, in the headlight of my Zongshen RX3.
08-26-2015, 02:38 PM | #98 |
I am very happy with mine.... it transformed a worthless headlight housing into something halfway decent.... I would love to see a pair of these in properly shaped/focused reflector housings instead of a $30 ebay POS....
