06-10-2016, 11:55 PM | #91 |
how many miles do you have on it now? Mine struggled to do 50mph until I had over 70 on it.
06-10-2016, 11:59 PM | #92 |
stock carb I shimmed the needle. I disconnected the line at the petcock, fuel flow looks good to me. I also got clear fuel lines and a fuel filter. When I plug in the fuel line after working on the carb and open the petcock it fills up quickly. I tried running with the petcock on reserve as well and no difference.
I am running 93 octane gas, Should be good quality. |
06-11-2016, 12:02 AM | #93 |
I have used 3 gallons of gas. Some of it got spilled out of carbs but I am guessing at least 150. I don't know exactly because I broke the speedo cable and haven't ordered a new one.
06-11-2016, 12:27 AM | #94 |
How many miles when you put the Mikuni in it? Better yet, don't answer and just try the stock one again.
06-11-2016, 11:32 AM | #95 |
Yes. I'm with PC, in that you can't begin to properly troubleshoot the condition without the proper needle in place. Have you tried to find another needle online? I bet they're super cheap.
Once you have the needle sorted, you can hone in on the correct jetting for your combination, at which point CDI failure would be easier to diagnose. Since you're seeing changes as you swap the main jet, I think the problem is entirely fuel-related at this time.
06-11-2016, 01:26 PM | #96 |
Where is the 'fuel filter' placed? Any chance you can check to see if there is an 'air bubble' trapped in the fuel line/filter? Wonder if that is (one of) the problems at higher RPMs
06-11-2016, 02:31 PM | #97 |
Fuel filter is just after the petcock. I have clear line before and after it and when I open the petcock I made sure there was no air bubble in the filter.
I am going to go back to the stock carb, Might even try the stock plug. The NGK is gapped a bit more than the stock but I believe it is still in spec. Some more info that I have that may or may not be relevent. Once when bike cut out with the 115 jet it locked up the rear wheel. Can you hydrolock the engine with fuel? It restarted with the electric start fine. When I did the valve adjustment with the spark plug out I still felt resistance when I was rotating the engine. It would be real easy then it would get hard to move. I assumed this is normal but figured I would mention it. I have 93 octane fuel in it and I saw another post where someone said that can make it run worse. I believe 93 does have slightly less energy but I don't think it is a material difference. Is this true? Also thanks to all who have helped me so far. If any of you are ever in RI let me know and I will buy you dinner |
06-11-2016, 07:15 PM | #98 |
I fixed it! I hit 50 going up a big hill and 65 going down the big hill.
It was valve lash. Not sure how I did it but I had the intake at like 1/4 inch or more. exhaust wasn't as bad but still way to much. Thanks again to everyone who helped. |
06-11-2016, 08:15 PM | #99 |
You must have set them on the wrong (exhaust) stroke the last time around instead of compression.
06-13-2016, 10:48 AM | #100 |
Glad to hear it's running well now.
06-13-2016, 11:45 AM | #101 |
Thanks!
I am going to wait till my new mikuni needle and pilot jets come in. I am running a 105 main and a 20 pilot and I assume it is running lean. I am at ~300 ft and have a pod filter and aftermarket exhaust with no cat. |
06-14-2016, 09:54 AM | #102 |
Wrapped the exhaust. I did a rather poor job so probably going to take it off and do it again. 50' of the 2" stuff can probably do the exhaust 3 or 4 times.
06-14-2016, 01:04 PM | #103 |
I'm surprised your bike will even start with a 20.
06-14-2016, 08:36 PM | #104 | ||
1971 Garelli Gulp 50cc with open ports and 16 mm Bing Carbie + 1980 Honda XL 223 ZS + 2007 Zongshen LZX200G + DR400SM |
06-14-2016, 10:15 PM | #105 |
I run a 20 pilot and it runs nicely. It is a mikuni that I set the needle on the lowest grove and turned out the screw 2 revolutions. I have a ngk iridium, not sure if that matters. I might try a 25 but for know it is running good. The main is a 110, that made a huge difference over the stock carb, which was a 98.
