Old 04-27-2012, 11:16 AM   #91
Do you plan to remove the gold anodized finish?
Old 04-27-2012, 11:22 AM   #92
gloud   gloud is offline
No I am just going to get a matching rear rim. Won't look stock but will be less maint with the anodizing. (and more than a few of my MX bikes had gold rims. My Maico 490 for example. (I really miss that bike, (power wise) but starting it was a real bother. It kicked back like a mule. I may try to find it this year.)
Old 04-27-2012, 11:34 AM   #93
if you don't mind a mild hijack, I have some questions on that topic. Son of Weldangrind and I are planning a Supermoto build, and we have a set of USD forks with a 17" front rim, but it's too narrow for our liking. If we used your zip tie trick, do you think we'd be able to transplant the existing spokes to a slightly wider 17" rim? Do we worry about spoke count only, or is there a potential for dissimilar spoke nipple angles? Thank you.
Old 04-28-2012, 05:47 AM   #94
The angle might be off a little. Mine thankfully was close enough. But the quality of the replacement rim was only OK, I was less than impressed with the weld seam and Final machine work on the rim. I was able to get it trued but with a decent quality rim the trueing would have been much quicker.
As such I may just paint the rim silver and not replace the rear rim.
If you are going to use a donor rim from a already laced wheel try to match the spoke pattern as close as possible.
Old 04-28-2012, 03:32 PM   #95
Thanks for the tips. I'll be sure to start a thread for the project and photo-document everything.
Old 04-29-2012, 06:38 AM   #96
Finished!
The only thing I had to tweak was the shifter (extend it and move it out from the case more) and the rear brake pedal so it would clear the pipe.
I added my $20.00 windshield I picked up at a swap meet this spring and Rode it for the first time with the tank on lol..
Overall very happy, it rides and handles better than it did on the test rides,
(a true front wheel and new tires and serviced forks help on that front.)
the gearing is about right, I dropped the rear sprocket down to a 45 tooth
with a 16 front I think and it is happy putting along at 50 with low revs.
After I shot these pics I adapted an old rear rack I had around to fir the XL. (still get to mount that today.) So I get to go back to commuting with the bike as I sold my Yamaha two weeks ago.
Old 04-29-2012, 11:19 AM   #97
WOW! :P
Outstanding work. The Chinamotor looks right at home in there! With the extra few cc's I bet it will perform just like it did whwn it was new. I'd like for Little Sweetie, my 1972 CB175, to meet your XL!
Old 04-29-2012, 12:37 PM   #98
Really impressive work! Thanks for the pics. Please show us the new rack, once it's installed.
Old 04-29-2012, 01:05 PM   #99
Thanks guys, See Doc you are not the only overly anal person in the shop lol..
I will get some pics of the adapted rack it was originally for my old Yam R5B (earlier RD350) and I have had it hanging on the old shop (On mom's property) Wall. Glad I kept it as it saved me fab time from building a whole new one. I spray painted it till I get the Powder coating setup I am lusting after..
Off to do some test riding (Yea thats the ticket LOL)
Old 04-29-2012, 04:32 PM   #100
katoranger's Avatar
Looks great. Another old Honda saved by China power.
Old 04-29-2012, 05:17 PM   #101
rack
I cut 4.5" out of the front of the rack and moved the rear mounts.
Took a 45 mile test ride and it ran well. came home and did an oil change and swapped in synthetic and topped up the tank with 93 octane. that really smoothed out the engine on the top end (I had regular in it before and it pinged a little). And it improved the shifting also.
I also had to swap out the new aftermarket front brake pads (drum brakes) as they where horrible. I swapped back in the OEM ones after cleaning them up and scuffing the drum up again, then lubed the cable (New OEM ).
Got it to stop decent (almost able to lock the front. ) I am going to find some OEM rear shoes as I suspect they will also work better.
One other thing I need to change is the color of the instrument cluster the aluminum reflects way too much sun. so it is going to be painted black.
Old 04-29-2012, 11:20 PM   #102
That rack looks right at home. What brand of aftermarket brake shoes were they? I can't remember if I asked you before, but where did you get those rear shocks? What brand of powder coating setup are you after?
Old 04-29-2012, 11:53 PM   #103
The entire bike looks beautiful! You did a good job on the luggage rack.
Old 04-30-2012, 08:34 AM   #104
davidsonsgccc   davidsonsgccc is offline
that bike looks sweet. it makes me want to redo my cb125 again.
my help may not be the best but it is free+-Seek ye first the kingdom of GOD
Old 04-30-2012, 09:11 AM   #105
SOK brakes. Horrible I think I could have stopped it better using an old leather belt glued to the shoes. I got them from Ebay. OEM were twice as expensive but I guess I should have known better. I still need to replace the rear and will go OEM Honda. I know they work.
I have heard good things about the powder gun from Eastwood so I will likely get their kit. To start off with I will get an old oven But I would like to build an oven big enough for a frame. (I have seen plans online Using oven elements for heat) But that is down the road.
The shocks are ebay specials, RFY (china) They actually work very well and I got them for 90 shipped. (scratch and dent sale they normally go for 110.00 shipped. ) The xl uses the same size as an RD350. I knew about them and was willing to try them as an RD I fixed last year for a guy had them and they rode decent. (Not as nice as Works shocks but they arn't 500.00 either) they are rebuildable also. (Important for guys like you and me. )
Had a great ride to work, Only issue was very minor, I need to adjust the idle mix. When I sit idling for a few mins it revs up a little. (lean I think)
Other than that it worked great.
