Old 11-23-2019, 02:16 PM   #76
ikeus685   ikeus685 is offline
Send a message via Yahoo to ikeus685
Cable lubers
Originally Posted by IronFist View Post
Someone posted a cable lube kit, the spray lube and a cable clamp, to keep the lube on the cable.
Tried to post a pix of these units off my phone but it didn't go thru $4.00 China and up. $7.00 and up in us for lubber unit that you put the nozzle from can into opening. Best done with cables off the bike but you can manage if you loosen attachment to brake or clutch, or throttle cable and inset the lubber and spray away. Old fashion way;.. insert nozzle as best you can into cable sleeve,. spray away.. work the cable slide back and forth.. invert cable(s) repeat..
If my picture doesn't come thru just input motorcycle cable luber into eba, amazon or whoever you use to get parts. Yea Pix came thru!!
