Old 04-28-2016, 10:54 AM   #76
detours   detours is offline
detours's Avatar
I've done a lot of work since Sunday:
  • 500 mile valve check ... still in spec.
  • Found a small radiator hose leak and tightened all clamps.
  • Fuel level fix by bending the tank float.
  • Installed my new GENNSI LED headlight.
Red 5 standing by!
2014 Ural Patrol
Old 04-28-2016, 01:30 PM   #77
Thanks for posting the great photos, Yoo. Why did you remove the fuel pump?
Old 04-28-2016, 11:57 PM   #78
winyoochanok   winyoochanok is offline
winyoochanok's Avatar
For clear Gasoline filter in tank,Sir.
Old 04-29-2016, 12:08 AM   #79
Thank you, Sir. Did you replace the filter with a new filter, or did you clean the old filter? If you cleaned the old gasoline filter, what method did you employ to clean it?
Old 04-29-2016, 11:30 AM   #80
RedHawk47   RedHawk47 is offline
RedHawk47's Avatar
I had my fuel pump out yesterday - I was thinking that the fuel level gauge was on that assembly (it is on my Guzzi and F800GS). I wanted to bend the arm.
I noticed that the filter is bent at a right angle against the bottom of the tank as shown in the photo. I think this fold makes 3/4 of the filter inoperable. I tried to rotate the filter to a more functional position but it would not move with moderate force, and I didn't want to break it.
Dan
CSC RX3 Cyclone, CSC TT250, Moto Guzzi V7 II, KLR650
Old 05-07-2016, 04:39 PM   #81
DoomWeasel   DoomWeasel is offline
DoomWeasel's Avatar
Last night I opened the RX3 up for surgery. I had 650 miles on the bike and it was time to adjust the valves. I found that the intakes were a little tight at .004 so I loosened them up to about .007. The exhausts were at .006 so I let them ride for now.
Today I rode about 200 miles around the Green Swamp and Withlacoochee State Forest. Here is my RX3 along the Withlacoochee River.
Eric
2016 CSC RX3 Sahara Orange
Old 05-07-2016, 04:42 PM   #82
dpl096   dpl096 is offline
dpl096's Avatar
Doom.... Any trouble with the bolts on the underneath side of the tank being only finger tight? Someone else on here found theirs to be loose.
― Thomas Jefferson
Old 05-07-2016, 06:14 PM   #83
dpl096's Avatar
Thumbs Up
Originally Posted by jontando View Post
I swapped out the stock 2015 handlebar for a ProTaper EVO Adventure in black (really the fastest color), They are a smidge wider, a teeny bit taller, and bar ends go in without drilling anything. I dig them.
SWEET ! ! Where did you buy them ? I love the way they offset the white.
― Thomas Jefferson
Old 05-07-2016, 07:25 PM   #84
DoomWeasel's Avatar
Dang it I knew there was something I was supposed to check out while I was under the tank. While I had the bike apart I did find why my horn seemed to only work when it wanted to. The wire disconnects were too loose. I squeezed them tighter with my pliers and they are now holding in place when I seat them.
Eric
Old 05-07-2016, 07:44 PM   #85
dpl096's Avatar
For those that don't remember take a look at post #19 : http://www.chinariders.net/showthrea...highlight=tank
― Thomas Jefferson
Old 05-08-2016, 02:51 PM   #86
surfndirt   surfndirt is offline
surfndirt's Avatar
What did I do to it? Rode.
'16 Red RX3, K270's, 13t Front, Fog lights, Tusk Bar Risers (4K mi.)
'82 Suzuki SP250 (11k Miles)
'85 Honda Rebel 250 (Sold April 2016)
Old 05-08-2016, 04:25 PM   #87
Eco Mouse   Eco Mouse is offline
Eco Mouse's Avatar
Would you mind telling me how much extra slack you think there was on the cables and lines after your install? I've been this close to pulling the trigger on the same bar, but in High. I need more stand up room.
Old 05-09-2016, 05:11 PM   #88
More farkles
In the last few days I have done the first service. While doing the oil change I added a quick drain.If you do this you will need the 16mm version. It's about 1/2 the price of the kit that CSC sells.
Next I swapped out the stock chain for a DID X-ring model. Joe talked about the stock chain only lasting about 6K miles and I figured the stock chain must not be O or X ring. Letting it go now would slowly erode the sprockets too so I made the move early and will keep the stock chain as a spare. It turns out that, at least for the '16 models, the chain is O ring.
Next I installed a controller for heated gear. Even this time of year it can get chilly and I'm spoiled with a heated liner. The controller is mounted on my GPS mount so it's within my line of sight and easy reach with my left hand.
Finally, it's nice to know what the electrical system is doing. I have a few micro voltmeters lying around and now there is one on the bike. Note it's in a protected location...lower right of the photo.
Almost forgot, the tall seat came in today. It looks like this might do the trick for making the bike more comfortable on a trip. If the weather clears I'll give the seat and new farkles a test ride.
Peter Y.
Old 05-09-2016, 08:08 PM   #89
superdude   superdude is offline
Hey surfndirt what size Kenda k270's did you go with for front? I know
they dont make them in 3.00-18 so did you go with 3.5 or 2.75 for the width? Curious to know thanks!
Old 05-09-2016, 09:41 PM   #90
surfndirt's Avatar
3.5
