Old 08-02-2016, 08:45 AM   #76
CSCDude   CSCDude is offline
CSCDude's Avatar
Originally Posted by rjmorel View Post
My 2015 is up to 9600 miles now after the Iron Butt 1000 ride. Took a licking and it's still ticking. Hope to get it over 10,000 by end of August. rj
I'm sure you will, Rob.
We're hoping to see you at the Horizons Unlimited gathering in Mariposa next month. CSC will have a booth there and I'll be one of the HU speakers. Let me know if you're going to be there, my friend.
Joe
www.ExhaustNotes.us
Old 08-03-2016, 12:36 AM   #77
rjmorel   rjmorel is offline
rjmorel's Avatar
Joe , I sent in my moola for both the Horizon Unlimited gatherings in Mariposa in Sept. and Nukusp, Canada just north of here across the border end of Aug. Barring anymore kidney stone problems I'll look forward to seeing you then. rob
Live Zong, and Prosper
Old 08-04-2016, 02:19 PM   #78
DoomWeasel   DoomWeasel is offline
DoomWeasel's Avatar
Originally Posted by willy dog View Post
good job speaking of jobs my rx3 has been at 3000 miles for a month 12 hour work days getting in the way of riding
Tell me about it. Mine has been sitting at 3300 since early July. Between the summer weather here in Florida (IE hot and humid or pouring rain), work, and other drains on my free time I haven't been able to ride other than a quick trip to the bank and post office the other evening. I did just put the Seat Concepts tall seat on the bike so I got to find some time to break it in.
Eric
2016 CSC RX3 Sahara Orange
Old 08-30-2016, 08:33 PM   #79
rjmorel's Avatar
12,000 miles on my RX3 now, running good need new tires, rj
Old 10-18-2016, 10:24 PM   #80
I just recorded 20,000 miles on the odometer this week.
Old 10-19-2016, 11:25 AM   #81
katflap   katflap is offline
katflap's Avatar
" The Zong master returneth "
Glad to hear you've added plenty of miles to your bike, spud. I hope they have all been good ones ..
Old 10-19-2016, 02:28 PM   #82
What tires are you looking at rj?
Old 10-19-2016, 03:07 PM   #83
Thank you, Kat. Yes, every mile on the RX3 is a good mile, especially since I switched to the lightest spring available for my Progressive shock absorber.
Old 10-19-2016, 03:56 PM   #84
rjmorel's Avatar
bought Shinko E705 130/80x17 for rear and kenda SR244 copy 3.50x18 front, not mounted them yet. May run thru the winter on whats mounted as they are still usable, rj
Old 10-19-2016, 04:44 PM   #85
Please refresh my memory; what was the rear tire you replaced?
Old 10-19-2016, 09:40 PM   #86
rjmorel's Avatar
Spud it was a Shinko SR244 that is bigger then stock size and rubbed the inside fender well. So I'm going back to a stock size tire. The new one is more like a big adventure bike pattern and not as aggressive as the sr244.
And welcome back to "the land of the sitters in front of computers" Spud. Glad you had a safe summer of riding. You going to have any summer ride reports to tide us through the winter ? rj
Old 10-20-2016, 12:55 AM   #87
Thank you, Rob.
Did you have the size 5.10-17, Shinko 244 tire installed? I ran that tire for 13,000 miles without problems. Did you post a photo or a thread regarding this problem? If so, please provide a link.
Yes, the winters here are long and hard, so I will be sharing a few photographs from my summer riding.
Old 10-20-2016, 12:09 PM   #88
willy dog   willy dog is offline
willy dog's Avatar
my 5.10-17s have had no problems with 285lbs of mass
Peace and Zong Life
Old 10-20-2016, 01:42 PM   #89
rjmorel's Avatar
Thank you, Rob.
Did you have the size 5.10-17, Shinko 244 tire installed? I ran than tire for 13,000 miles without problems. Did you post a photo or a thread regarding this problem? If so, please provide a link.
Yes to Shinko 5.10x17 244 tire .Others have posted that it rubs. In my case I put on Progressive shock and lowering link and I think this combination lets it grind a bit on the inner fender. If I tightened preload some it probably would not happen. This last trip I was loaded and preload was a little light so bottomed out a few times on fender. I figured if it was bottoming out , I was at least using all available travel so I was getting my moneys worth
13,000 miles wow .I'm at about 4400 but that is iron butting it all day on pavement it still has enough tread to get me thru to spring and then some. heres a picypoo taken a few days ago.
rj
Old 10-20-2016, 02:03 PM   #90
As always, thanks for posting your detailed, informative reply, Rob. I think you are correct; the combination of a large tire, Progressive shock absorber and lowering link caused the problem.
If you lace a 2.50-17 rim to the rear hub, you can install the size 4.60-17, Shinko 244 tire. This tire is lighter and smaller in diameter, which might eliminate the problem, and also lower your saddle height a little. I have been running the 4.60-17 tire for about 7,000 miles, and it has done a good job. However, it now needs to be replaced, so the smaller, size 4.60-17 tire only got 55% of the wear life I received from the larger, size 5.10-17 tire.
