Old 08-29-2015, 12:45 AM   #76
Jasonbber   Jasonbber is offline
Originally Posted by rich_e View Post
Vermont cashed the check I sent them for the registration on the 150. I assume that means they'll be sending me the the tags soon . Just to recap: I just followed the guidance posted at http://www.chinonthetank.com/2014/04...-registration/. Filled out form, attached bill of sale, computed sales tax + fees, attached check, and mail it all in. That was on 14 August. On 26 August, they deposited the check.
I guess I'll go ahead and put some turn signals on it this weekend. Wiring is still there but the signals are long gone.
I got the speedometer working. Ordered the wrong cable. I was able to cut the fittings off my old cable housing and install them on the new cable housing. Couldn't just replace the cable because the housing was shredded.
This is such good news. I am going to register one of my bikes today. I ordered the throttle cable you posted. It came in but the male adjuster was way to big looked like it went to a four wheeler. They were the correct length so I cut the old cable male input off with a Dremel and made a line down the center to slip the cable through and now it works great. I pulled my carb off and the pilot get was clogged in my 150cc and the main jet had vibratted completely loose. I put everything back together on the 150cc and everything ran great for about a min until the jets got clogged again with rust from the gas tank. Now I'm looking into what other tanks will fit in case I want to switch it out. I saw several Apple cider vinegar videos but I'm skeptic. I flushed my tank several times but each time more and more flakes.
2004 panterra 125cc
2004 panterra 150cc
1989 Yamaha yz 250cc (sold)
1988 Kawasaki Kdx 200cc
Old 08-29-2015, 02:12 AM   #77
rich_e   rich_e is offline
I was thinking of trying the plastic tank from my h-bird just see if it would fit in the 150.
Old 08-29-2015, 03:25 AM   #78
Please do and let me know if it does because the options for tanks are limited on these when looking at xl, Xr and cb style tanks.
I checked out my vin and its a Chongqing Loncin. Also I looked on the nhtsa site and found their vin decoding info. My bike is labeled as a cross country motorcycle the vin starting with LLCHY the first three designating the location,company, and division 4th the brand and 5th type of vehicle.
How did you list the bike on the bill of sale? What's it going to say on the title?
2004 panterra 125cc
2004 panterra 150cc
Old 08-29-2015, 04:09 AM   #79
demidestructo   demidestructo is offline
demidestructo's Avatar
wow you really did a nice job on your bikes. Your bike is has a 150cc like mine but I have a lifan motor instead. The bikes look the same to me ,I am swapping in a aluminium swingarm from a cr500 .I want to save weight as much as possible plus a little longer swingarm will come in handy if i build the motor I'm thinking of now. A turbo 218 (xr200 with crf230 crank and ecotronics 34mm fuel injection with turbo and water/meth injection to suppress detonation) I am taking off parts I an't find and remaking them in aluminium because my buddy is lead fab at a custom race snomobile shop . Since we have same bike if your or others are interested I may make a few. I never have done things cheap or half-butt and I have no desire to start now so the pieces will be flawless. Ok well head over to my thread sometime and check me out.have a good day Brad
Old 08-29-2015, 02:30 PM   #80
I listed the bike as a "Xgjao" for the make and as "XGJ150GY-3A" for the model. I suppose you should just put "Loncin" for your make.
I got the tag today. They send the ownership certificate later. I don't know if there's supposed to be an expiration sticker on the plate. There wasn't one.
Old 08-29-2015, 09:26 PM   #81
Dirt Runner
All done with the Baja Dirt Runner. Cleans up real nice! Runs great. Just listed on Craigs list. Little to small for me and to big for any of my grand kids.
Old 08-29-2015, 11:51 PM   #82
It looks good; it should sell quickly.
Old 08-30-2015, 12:26 AM   #83
You did a very nice job.
Old 09-01-2015, 11:01 AM   #84
Turn Signal Wiring
I'm trying to get the turn signals working on the 150 now that I have a plate. I hooked up all the signals. When I hit the signal switch all I get is the warning beeper, no lights, no flashing. The sound appears to be coming from the flasher unit, so I assume it's getting current. But there's some other device in the loop and I don't know what the heck it is. It doesn't show up on any of the wiring diagrams I can find. It has all the colors of the signal wires. The wires go in but there's no exit. Is it some kind of flasher? Anyone have a basic diagram I can wire from scratch to get around what ever this little box is?
Old 09-01-2015, 11:26 AM   #85
I can take a look at mine when I get home later today. I just hooked mine up so Ill just take a picture of it. It sounds like you may have a bad relay for your blinkers or you have some wires crossed.
2004 panterra 125cc
2004 panterra 150cc
Old 09-01-2015, 11:33 AM   #86
I have dealt with a similar issue, so I hope this helps. Start reading from post #62: http://www.chinariders.net/showthrea...=camwow&page=5
Old 09-01-2015, 12:06 PM   #87
So the thing that looks like a flasher (with two wires) is just the beeper and the other box (the pictures I posted) is actually the flasher?
Old 09-01-2015, 09:07 PM   #88
It was just the flasher. Confused me because it beeped. But I tried the one out of the hi-bird and everything worked.
Old 09-02-2015, 12:10 AM   #89
Glad to hear you got it sorted.
Old 09-02-2015, 11:05 AM   #90
I still don't know what that other box does, the one I posted a picture of. Some sort of relay?
