Old 06-16-2015, 01:16 PM   #76
Originally Posted by rjmorel View Post
Spud, here's what I did for my aging back to get it up on center stand easier out in the field.
http://www.chinariders.net/showthrea...d=1#post187142
The Husky jack would be more challenging to take out on a ride I must admit, rj
Thanks for posting that great tip, RJ. In a pinch, one could also roll the rear wheel onto a flat rock.
Old 07-01-2015, 05:38 PM   #77
dave92029   dave92029 is offline
Thank you for posting this tutorial
Thank you for this tutorial and all the helpful comments. You guys gave me confidence to adjust my shock today.
I took a slightly different approach. I removed the heat shield from the exhaust pipe and the clamp that secures the pipe. This gave me access to the shock, even with my very large hands.
I then used a 5/32 Hex socket from my 10pc HF hex set to loosen the retaining ring.
I only tightened my shock 3 full rotations. This is a big improvement. I might need to tighten an other turn but I'll ride the bike for a while and see how this feels.
I found that both my tires were delivered with approx 6 lbs more air pressure than the owners handbook suggests, so I brought the tire pressure inline with the handbook.
I also softened the rebound dampening.
The bike has about 400 sMiles on her in the first week so we are still getting to know each other. I'm really enjoying the ride.
Old 07-01-2015, 07:36 PM   #78
Thanks for the kind words and updating the thread with your personal experience regarding the preload adjustment procedure.
Old 07-01-2015, 08:19 PM   #79
fishman10's Avatar
dampening
i've adjusted my dampening to no avail to slow down the rebound dampening ,it only has one click left,,,sigh
2015 zongshen rx3,,(Sold),,,2016 bashan storm,,2005 Harley ultra classic.
Old 07-02-2015, 01:52 AM   #80
If/when CSC starts selling an aftermarket shock absorber, I will certainly be buying one. How about you, Fish?
Old 07-02-2015, 09:25 AM   #81
fishman10's Avatar
praying for new shock
if csc's pricing is fair ,,,yes indeed!! i will buy .... it will transform this great little bike!,,,i think even the stock shock on mine is defective as it seems to have no dampening ,, just a spring effect ,,as it trys to launch me at times . On a side note ,,,,it runs much better now that the valves are adjusted..
Old 09-07-2015, 08:14 PM   #82
rtking   rtking is offline
As always, thanks to Spud and all that posted on doing the preload adjustment. As a big guy, the stock setting had me bottoming the shock with any kind of bounce on the seat. Following the guide posted by Spud, I was able to access the Allen Head screw that was facing rearward by removing the battery. I gave 8 turns to the coil/collar which firms up the spring quite a bit, and I oriented the collar's lock screw toward the left side of the bike so I can now back-off the screw without having to disassemble the side panels and battery.
8 turns feels pretty stiff, but the bike handled pavement great. I think for any kind of off road use, I'd probably back off the preload by 2 turns and get it back to 6 turns tighter/stiffer from the stock setting.
I also changed the oil today (after 58 hard break-in miles) and was glad to have done so. There was what I am assuming to be assembly lube and metal particles around the drain plug, and around the screen filters. This was expected. But I feel better putting fresh dino-oil (Valvoline 4T 10w-40) into the bike, and the bike rewarded me with an easier time finding neutral.
I am loving this bike more and more each time I ride it!
Old 09-07-2015, 09:28 PM   #83
3banger   3banger is offline
3banger's Avatar
I'm curious where people are setting up there rear shocks? Here is where I left mine; the preload measurment is the exposed threads on the shock body.
Old 09-14-2015, 01:13 AM   #84
Interesting. Seems mine was set really loose from the factory. In the attached image, you can see the darker area of the shock body is where the stock setting was. I didn't measure sag, but tried to follow your table (see below.)
8 turns stiffer was indeed pretty stiff, but rode well for my weight (well north of 230 lbs) on smooth highway. Backing off one turn (to 7 turns total toward stiffer) seems to yield the best compromise... but I'll test it out more this coming weekend when I can go for a longer ride.
Just a note that, turning the collar so the Allen head lock-nut on the collar is facing the left side of the bike made adjustment so much easier. A long extension and I can release the Allen head screw, and using leather work gloves, I can reach the spring from the left side and from behind the mud flap to rotate the spring (after unloading the shock, of course.) Very easy.
Name:	Screen Shot 2015-09-13 at 10.07.53 PM.png
Old 03-28-2017, 06:47 PM   #85
jogirob   jogirob is offline
jogirob's Avatar
2016 adjustable rear shock difference?
I didn't see any mention of the adjustment screw on the bottom of the shock/spring assembly. It has and "increase/decrease" setting. Is this something new for the 2016 models? Or is this screw for fine tuning?
Old 03-28-2017, 07:28 PM   #86
jbfla   jbfla is offline
It is a rebound damping adjustment.
I spent hours going back and forth over bumpy pavement to get the adjustment right for me.
I changed the setting one click at a time, then tested.
Others have said they could not feel the difference from on setting to the next.
For me it made the ride go from spine jarring to tolerable.
jb
2014 XT 250........
Old 03-28-2017, 07:46 PM   #87
Jay In Milpitas's Avatar
It's not new, it is also on the 2015 models.
Horse holder at Madame Orr's House.
Old 03-28-2017, 08:21 PM   #88
jogirob's Avatar
Ah OK thanks for the explanation. The screw is actually shown one of the first photos posted in this tutorial. I don't know how I missed it!
Old 04-21-2017, 05:25 PM   #89
GSC   GSC is offline
adjusted pre-load today.
went in from left side after disconnecting PCV line from bottom of airbox, two hands with right hand under mudflap makes turning easy.
#4 allen loosened the collar, added 3 turns clockwise or down, job done.
my off road ride much improved.
thanks people for good advise on many ways to gain access.
Old 01-08-2018, 11:34 PM   #90
nextor   nextor is offline
Im doing this procedure. But the spring is very hard for my hand and only do 4 turns around the spring with my hand. You know any procedure for can do more turns? Thanks-
