Old 03-03-2016, 08:32 PM   #76
bogieboy's Avatar
uhh... couldn't tell ya....LOL I got it off the bulk roll at work (I'm a tractor mechanic)
Old 04-09-2016, 04:10 PM   #77
chuck   chuck is offline
Originally Posted by bogieboy View Post
actually no...
front wheel is stock speedo drive in the stock spot, stock spacer on the brake side, and then 3-5 washers to make it all line up proper (i forgot how many i used...LOL)
out back its stock right side spacer of the brake mount, wheel, cush drive, and then just the stock spacer on the left...i ened up using the ninja spacer, even though its pretty similar in size...LOL I paid for em i may as well use em...LOL and no washers out back.
its a fairly straight forward bolt up affair once you swap out the 17 and 15mm bore bearings for 15 and 12 mm bores to fit the axles...
the rear end, aka the wheel and cush drive i used:
one B15-86D-2RS
one LR202NPP
one 949100-3820/B382 AB
for the front i used a pair of:
LR201NPP
and all of those can be sourced from ebay for around $10 each if anyone else is interested! i can shoot links if anyones interested...
Can you shoot some links for all.Thanks
Old 04-13-2016, 12:25 PM   #78
bogieboy's Avatar
ok bearings... front needs a pair of these (assuming your axle bolt is 12 mm diameter.)
rear uses one of these, one of these and the cush hub uses one of these.
Old 04-14-2016, 11:15 AM   #79
Thanks once again.
Old 01-05-2017, 12:01 AM   #80
95C1500   95C1500 is offline
Old thread, but I'm looking into this now. Any more updates?
Old 01-05-2017, 06:09 AM   #81
bogieboy's Avatar
Not really much to update? I have put 6k miles on the setup with no issues.
