#76 |
I can see some residue around the fork cap, on the upper triple clamp. As Spud says, try tightening the cap a little.
#77 |
I forgot to mention, loosen both bolts in the top part of the triple tree clamp before you attempt to tighten the fork cap.
#78 |
You guys know what kind of fork seal I need for the Vento?
Hector Mountrack Vento 2006 |
#79 |
Other than paint color and graphics, you Mountrack Vento is identical to my Zongshen 200GY-2.
![]() http://www.chinariders.net/showthread.php?t=6051 Everything you need to know about changing your fork oil and seals is included in the following thread. ![]() http://www.chinariders.net/showthread.php?t=10266
#80 |
You can order Zongshen, fork oil seals from Taobao.com, or you can order a Honda, fork seal set, part #51490-GBF-J21, for the '09 Honda CRF150R.
#81 | |
http://www.chinariders.net/showthread.php?t=12183 ![]() ![]()
Zongshen 200gy-2 |
#82 |
I will buy the oil seals at Honda (although it takes about 2 months to get them) meanwhile will read your threads before hands on. Thanks to everybody for the feedback.
Cheers
#83 |
Spud's thread taught me how to service my forks. It was very helpful.
#84 |
Spud, is there any thread about the electric starter motor?
#85 | |
![]() Your brake pads are squeaking because they are wearing unevenly. You need to remove both brake pads, and either grind, or cut away the higher surface at the rear of the brake pads. I suggest you read the following thread on this topic. http://www.chinariders.net/showthread.php?t=4585 Please do start a new thread for each of your future problems, rather than posting the problems in this engine rebuild thread. ![]() If you start a new thread on each specific problem, that topic and its associated thread will serve as a future resource for others. ![]() ![]()
#86 |
Hect75, if you choose to grind your pads, be sure to wear a dust mask or respirator.
