Old 09-21-2012, 12:51 PM   #76
Don't forget to remove the outer layer of the air filter and oil the inner foam. As I've mentioned, I like Maxima Fab1 spray oil, which is available at most bike shops. It's blue (which is really easy to see) and it sticks like cobwebs; follow the instructions on the label.
Doc, Coors Lite is training beer.
Old 09-21-2012, 01:15 PM   #77
450-WheelieBoyz   450-WheelieBoyz is offline
Send a message via MSN to 450-WheelieBoyz
alright, ill grease her up real good :P
like i said im going shopping after work
Ordered:
-Hydro-Clutch RECEIVED!!
-Air filter RECEIVED!!
-30mm Mikuni
-Jets : 110-M 25-S
-Chain : 428-128L
Buying:
-Tools i need for the rebuild
-Motor oil
-Air filter oil
-Chain lube
-Walmart bicycle speedometer
-Crazy carpet
-Red nail polish :P
with that ill be good for the rebuild and have enough lubes n stuff for the rest of the season.
450-WheelieBoyz a.k.a. BlockHustler1000
-2011 X31 Gio 250cc-
Mikuni Upgrade
Air filter
Hydro-clutch
Reppin -> Montreal, Quebec, Canada
Old 09-24-2012, 09:10 AM   #78
Here's my favourite filter: http://www.ebay.ca/itm/42mm-Air-Filt...item4ab686abc4 I use Maxima Fab1 filter spray oil on it.
Spud has had excellent luck with Tsubaki chains, and they're very reasonably priced online.
The filter didnt fit, just for future reference.... i had to McGyver an adapteur to get it to fit .
ill post new threads with pictures shrotly
Old 09-24-2012, 09:54 AM   #79
KDocherty   KDocherty is offline
Haha Mcgyver, are you going to post pics as you do the jobs would be quite informing to read along to.
Old 09-24-2012, 11:26 AM   #80
Im not sure if i should keep this thread going... or make new individual threads ex. How to install a hydro-clutch GIO X31, how to install an air intake GIO X31, how to install mikuni carb GIO X31..... or do a big Rebuild/upgrade thread..
Weld, what do you think i should do? rebuild thread or individual how-to's ???
Mikuni Upgrade
Air filter
Hydro-clutch
Old 09-24-2012, 11:41 AM   #81
can we get a section for Tutorials and or How-to's?
thanks in advance Monsieur SoudeurGrindeur hehe
Mikuni Upgrade
Air filter
Hydro-clutch
Old 09-24-2012, 12:36 PM   #82
Il n'ya pas de quoi (think nothing of it). I'm happy to help, but I'm sorry that your filter didn't fit.
I recommend that you start several threads for easy searchability, and then start one thread that lists all of your threads as links, just like M. Patate (Mr. Spud) did. Check out his sticky in the Dual Sport forum, and you'll see what I mean.
Old 09-24-2012, 01:17 PM   #83
it would be better possibly just to sticky them unless there is loads hate loads of stickys ha !
Old 09-24-2012, 01:37 PM   #84
YAAAAYYYY
Old 09-24-2012, 01:39 PM   #85
Just to confirm, the pilot jet is attached to the main jet in these pics right???
Old 09-24-2012, 05:09 PM   #86
It looks like the slow jet is next to the main jet. The pilot mixture screw is on the bottom side of the carb, near where it bolts to the intake tube. make sense?
Old 09-24-2012, 06:36 PM   #87
is the idle is still the screw on the right side, on the opposite side of the choke?
Old 09-25-2012, 01:36 AM   #88
That's right.
Old 09-25-2012, 12:10 PM   #89
ok ok. so for the pilot mixture, i screw it all the way in, then 1.5 turns out. corect?
thanks again Weldy, u-da-man!
Mikuni Upgrade
Air filter
Hydro-clutch
Old 09-25-2012, 12:53 PM   #90
Correct. Just be really gentle when turning the pilot screw in.
